[gdal-dev] Deciding whether to use WFS paging after opening the datasource
Even Rouault even.rouault at spatialys.com
Wed May 3 04:52:33 PDT 2023
Craig,
Both options you propose are reasonable. I'd perhaps have a slight
preference for option 2 (is my understanding correct that the user would
be responsible to issue GetFeatureCount() manually before calling
GetNextFeature() ? we don't want to systematically call
GetFeatureCount() because it could be potentially a rather costly
operation for some servers).
It could be enhanced with allowing a CHECK_WITH_HITS value for
OGR_WFS_PAGING_ALLOWED (or perhaps through a new specific open option ?)
that would automatically issue the feature count request (that could be
useful for ogr2ogr types of scenario where the user can't easily cause
ogr2ogr to issue GetFeatureCount())
Even
Le 03/05/2023 à 03:10, Craig de Stigter a écrit :
> Hi folks
> We're having trouble with OGR trying to fetch a response from this
> WFS2 URL:
> https://geo.irceline.be/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=realtime:pm25_24hmean_station&COUNT=1000000&STARTINDEX=0
> <https://geo.irceline.be/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=realtime:pm25_24hmean_station&COUNT=1000000&STARTINDEX=0>
> The error from the server is
>     Cannot do natural order without a primary key, please add it or
>     specify a manual sort over existing attributes
> This seems fair enough on the surface - we specified *STARTINDEX=0*
> but the server is unable to support paging for this dataset due to no
> natural sort order.
> We'd happily disable paging for this dataset - it has a fairly low
> number of features - but we would prefer to implement a general
> purpose solution rather than special-case this particular dataset.
> It would make sense to open the datasource, check the feature count by
> doing a 'hits' query (we're doing this anyway), and then use paging if
> there are more than 1000000 features - otherwise don't use paging.
> However I can't find a way to accomplish this with GDAL. The
> *OGR_WFS_PAGING_ALLOWED* config var is only checked when the
> datasource is opened - so you can't open the datasource, check the
> feature count and then change the paging behaviour.
> I can imagine either of these changes in GDAL itself might fix this:
> 1. GDAL could check *OGR_WFS_PAGING_ALLOWED* when actually first
> issuing GetFeature requests, rather than during datasource creation
> 2. GDAL could omit the pagination parameters if the feature count is
> already known and is less than the page size
> How would you suggest we proceed?
> Regards,
> Craig
> Platform Engineer
> Koordinates
> +64 21 256 9488 <tel:+64%2021%20256%209488> / koordinates.com
> <http://koordinates.com/> / @koordinates <https://twitter.com/koordinates>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230503/e3a96647/attachment.htm>
