[gdal-dev] JPEG2000 change progression order without decoding
Even Rouault even.rouault at spatialys.com
Wed May 3 05:25:40 PDT 2023
I don't have in mind OSS to do that, but the kdu_transcode utility from
Kakadu (proprietary) should be able to do it. Cf
https://trac.osgeo.org/gdal/ticket/3295 /
https://kakadusoftware.com/wp-content/uploads/Usage_Examples.txt
Le 03/05/2023 à 04:20, Tobby Moalem a écrit :
> I wonder if there is a way to change the progression order of jpeg2000
> images, without the need of decoding it and then encode it again. For
> example if I have an image with RPCL progression and I want to convert
> it to LRCP. Is there a way to only move bits around (change the order
> of the file) instead of needing to transcode the image all over again
> (which may take a long time)?
> Thanks in advance,
> Tobby
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
