[gdal-dev] Space Disk/Memory of Image
Elena Ruiz eruiz at aplitop.com
Tue May 9 01:47:39 PDT 2023
Hello, I need to know the disk size of an image, I calculate it using the following formula:
Disk size=( sizex*sizey*bits per pixel)/8 =memory size without compression
But when the image is compressed on disk it occupies less and the size in memory is much larger, is there some method in the C++ GDAL API, to obtain the size on disk, size on memory, or the compression factor?
Example:
SizeX: 60416
SizeY:38656
Bits per pixel:24
Size memory= (60416*38656*24)/8=7.006.322.688 bytes
Size disk=2.137.644.631 bytes
The format image is COG - Cloud Optimized GeoTIFF generator, and has JPEG compression
Thanks and regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Sofware Development & Technical Support
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 M?laga (Spain)
www.aplitop.com
[cid:SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png]<https://www.facebook.com/AplitopSL/>   [cid:SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png] <https://twitter.com/aplitop>    [cid:SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png] <https://www.linkedin.com/company/aplitop>    [cid:SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Protecci?n de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
<https://www.aplitop.com/New/en/443/publication-of-point-clouds-on-web>
<https://www.aplitop.com/New/en/438/tcpmdt-v9-is-here><https://www.aplitop.com/Event/en/429/aplitop-at-intergeo-2022-essen>
<https://www.aplitop.com/Event/en/358/intergeo-2019>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/fb19a843/attachment.htm>
Type: image/png
Desc: SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/fb19a843/attachment.png>
Type: image/png
Desc: SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/fb19a843/attachment-0001.png>
Type: image/png
Desc: SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/fb19a843/attachment-0002.png>
Type: image/png
Desc: SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/fb19a843/attachment-0003.png>
