[gdal-dev] GRIB can't get nodata and cmake can't disable FileGDB
Ivan Lucena ivan.lucena at outlook.com
Fri May 12 10:02:03 PDT 2023
Hi Even,
I was using GCC 4.8.5 on Linux and getting the same error in openfilegdb as mentioned in (fixes #6991<https://github.com/OSGeo/gdal/issues/6991>).
So, I did what you suggested, and build GDAL 3.6 without a problem.
My mistake is that I was traying to get rid of the error by turning off the wrong driver (filegdb)!
So, everting seems to be fine with cmake. Great job in the transaction from autoconf, BTW.
And thanks again for fixing the GRIB driver. (fixes #7673, #7674).
Best regards,
Ivan
Sent: Saturday, April 29, 2023 9:34 AM
To: Ivan Lucena <ivan.lucena at outlook.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] GRIB can't get nodata and cmake can't disable FileGDB
Ivan,
(I see you've filed an issue for the GRIB nodata issue since.)
But I am getting a compilation error, somewhere on ogrsf_frmts/openfilegdb, and I cannot turn off that driver on cmake. The parameter -DGDAL_USE_FILEGDB=OFF seems to work fine.
For the OpenFileGDB driver, this should be -DOGR_ENABLE_DRIVER_OPENFILEGDB=OFF
-DGDAL_USE_FILEGDB=OFF is to disable the use of the proprietary SDK
I somehow recall someone had mentioned a building issue some time ago but can't find it. Anyway, I assume you may perhaps use an older compiler, like MSVC 2015 which we no longer test/support and that doesn't support some aspects of C++11. You may perhaps try to revert https://github.com/OSGeo/gdal/commit/b8076543f0fefb7106351297b845df2f8b4d8514 alternatively, or better upgrade to something more recent
More generally when you report something, be very specific and post exact error messages.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230512/eeca4527/attachment.htm>
