[gdal-dev] Shapefile with corrupted index: SHAPE_RESTORE_SHX=YES doesn't correctly repairs it.
Andrea Giudiceandrea andreaerdna at libero.it
Tue May 16 05:02:23 PDT 2023
Il 16/05/2023 13:52, Jan Heckman ha scritto:
> Also out of curiosity,
> Are you willing to share the shapefile, preferably at least shp and dbf,
> but probably .shp alone will do and .prj helps for checking conversion
> results.
Hi Jan,
the corrupted Shapefile layer is available in the QGIS issue report at
https://github.com/qgis/QGIS/issues/53058
Best regards.
Andrea
