[gdal-dev] Spatial view in GeoPackage
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Sat May 27 13:08:21 PDT 2023
Hi list -
I'm working with making spatial views "visible" for QGIS, i.e. so they
look like a read-only table from the data source manager.
However, I have one problem:  QGIS doesn't recognize the crs for the
view. I've tracked the problem down to that *OGR* dosn't recognize the
crs for the view. Hence this mail...
What I've done:
*- creating the view: A union of parcels with the same owner (CVR-number)
CREATE VIEW marker_2019_cvr AS
   SELECT "CVR", SUM(COALESCE(st_area(geom),0.0)) as area_m2, count(*)
as antal, st_multi(st_union(geom)) as geom from marker_2019 group by 1;
-- insert or update gpkg_contents
INSERT OR REPLACE INTO
gpkg_contents(table_name,data_type,identifier,min_x,min_y,max_x,max_y,srs_id)
   SELECT
     'marker_2019_cvr' AS table_name,
     'features' AS data_type,
     'marker_2019_cvr' AS identifier,
     MIN(ST_MinX(geom)) AS min_x,
     MIN(ST_MinY(geom)) AS min_y,
     MAX(ST_MaxX(geom)) AS max_x,
     MAX(ST_MaxY(geom)) AS max_y,
     25832 AS srs_id -- same srs as the base layer for the view
   FROM marker_2019_cvr;
-- insert or update gpkg_geometry_columns
INSERT OR REPLACE INTO gpkg_geometry_columns ( table_name, column_name ,
geometry_type_name, srs_id, z, m)
   VALUES ('marker_2019_cvr', 'geom', 'MULTIPOLYGON', 25832, 0, 0);
-- insert or update gpkg_ogr_columns (necessary ?)
INSERT OR REPLACE INTO gpkg_ogr_contents(table_name,feature_count)
   SELECT
     count(*) AS feature_count
AFAIK, this is the necessary steps to make a spatial view visible in a
GeoPackage. And it works; sort of...
The QGIS datasource manager shows the view as a spatial table. I can add
it to the QGIS map, but... it can't find the CRS for the layer and
defaults to the projects CRS.
Digging a litle bit deeper: Using ogrinfo like this:
*ogrinfo -ro -so data_marker_vandloeb_soe.gpkg marker_2019_cvr*
shows the layers SRS WKT as (unknown).
Using the same command on the base layer *marker_2019 *gives the correct
WKT.
25832 is the correct EPSG number for the CRS. And the definition exists
in the *gpkg_spatial_ref_sys* table.
What am I doing wrong ? Or is it just "out of scope" for OGR ??
Med venlig hilsen / Best regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230527/0c0e3644/attachment.htm>
