[gdal-dev] configuration option GDAL_RASTERIO_RESAMPLING
Michael Sumner mdsumner at gmail.com
Sat May 27 18:05:35 PDT 2023
Ah great thanks, interested to help flush these out.
Cheers, Mike
On Sun, 28 May 2023, 10:34 Daniel Baston, <dbaston at gmail.com> wrote:
> Hi Mike,
> The content on the page you linked is for the most part a simple transfer
> of what was available on the wiki, plus a few options that were previously
> defined on driver or other pages. It is not complete.
> There are also about 500 configuration options that are used in the code
> via CPLGetConfigOption that do not appear in the documentation,
> GDAL_RASTERIO_RESAMPLING being one of them. Some of these are clearly not
> intended to be part of the GDAL interface, but there's still quite a bit
> that can be added to the documentation. I can create an issue and post the
> script I used to scan for these if others are interested in filling some of
> the gaps.
> Dan
> On Sat, May 27, 2023 at 8:18 PM Michael Sumner <mdsumner at gmail.com> wrote:
>> Hi, I'm very happy to see the refactor of documentation for configuration
>> and environment options, primarily by Dan Baston in recent weeks - thanks!
>> https://gdal.org/user/configoptions.html
>> Does the GDAL_RASTERIO_RESAMPLING option belong in this list?  I'm
>> exploring its use versus setting resampling with the API, and I gather also
>> that there is not an analogous config option for the warper.
>> Thank you, Mike
>> Michael Sumner
>> Software and Database Engineer
>> Australian Antarctic Division
>> Hobart, Australia
>> e-mail: mdsumner at gmail.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230528/1b8bac4b/attachment.htm>
