[gdal-dev] Spatial view in GeoPackage
Even Rouault even.rouault at spatialys.com
Sun May 28 12:52:03 PDT 2023
Jukka,
currently the driver doesn't try to use the RTree of the base table (it
could probably do it, but it would require first to check that both the
FID column and geometry column of the same underlying table are available)
Jukka, Bo,
Regarding the use of Spatialite functions, I think the cleanest way is
to define an extension to register such computed geometry column. That's
what I've done in
https://github.com/OSGeo/gdal/pull/7848/commits/8d7468f5342e3e9e54c11c913b8ca53f3effc4b3
. It is the responsibility of the user creating the view to register the
extension for its table, as show in
https://github.com/OSGeo/gdal/blob/8d7468f5342e3e9e54c11c913b8ca53f3effc4b3/doc/source/drivers/vector/gpkg_spatialite_computed_geom_column.rst#extension-name-or-template
The
https://github.com/OSGeo/gdal/blob/master/swig/python/gdal-utils/osgeo_utils/samples/validate_gpkg.py
script (once updated by the PR) will use that to avoid erroring out.
Even
Le 28/05/2023 à 19:12, Rahkonen Jukka a écrit :
> Hi,
> Fixed for this use case, but what if user wants to use  ST_Tranform(…
>  in the view? Or something that may change the geometry type like
> ST_Intersection, ST_Buffer etc? In these cases I think that at least
> the usage of the spatial index of the main table should be disabled.
> But how could GDAL know when to skip the spatial index and when not?
> With a special column in gpkg_ogr_contents perhaps?
> Somehow I do not feel comfortable. Maybe there should be a warning in
> https://gdal.org/drivers/vector/gpkg.html#spatial-views that
> SpatiaLite functions should be used carefully in the views and such
> databases should be delivered only for known users, while views with
> uncomputed geometries should be safe and interoperable.
> -Jukka Rahkonen-
> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Even Rouault
> *Lähetetty:* sunnuntai 28. toukokuuta 2023 0.39
> *Vastaanottaja:* Bo Victor Thomsen <bo.victor.thomsen at gmail.com>;
> gdal-dev at lists.osgeo.org
> *Aihe:* Re: [gdal-dev] Spatial view in GeoPackage
> Bo Victor,
> there was indeed a bug in the OGR GPKG driver preventing you to do
> what you wanted. Fixed per https://github.com/OSGeo/gdal/pull/7848
> The issue was specific to the fact that the geometry column of the
> view is computed, and not just the simple selection of one of a table.
> Note that such GeoPackage will probably only be readable by
> implementations that install Spatialite (or Spatialite compatible
> functions). It might also be prudent to wrap the result of ST_Multi()
> with AsGPB() to force creating a GeoPackage geometry blob instead of a
> Spatialite one. The OGR GPKG driver is tolerant to receiving both
> types of geometries, but technically the content should be a
> GeoPackage one.
> Inserting into gpkg_ogr_contents is optional. Its purpose is to
> accelerate counting the number of features. But for layers < let's say
> 100 k features, it probably doesn't impact performance much.
> Even
> Le 27/05/2023 à 22:08, Bo Victor Thomsen a écrit :
>     Hi list -
>     I'm working with making spatial views "visible" for QGIS, i.e. so
>     they look like a read-only table from the data source manager.
>     However, I have one problem:  QGIS doesn't recognize the crs for
>     the view. I've tracked the problem down to that *OGR* dosn't
>     recognize the crs for the view. Hence this mail...
>     What I've done:
>     *- creating the view: A union of parcels with the same owner
>     (CVR-number)
>     CREATE VIEW marker_2019_cvr AS
>       SELECT "CVR", SUM(COALESCE(st_area(geom),0.0)) as area_m2,
>     count(*) as antal, st_multi(st_union(geom)) as geom from
>     marker_2019 group by 1;
>     -- insert or update gpkg_contents
>     INSERT OR REPLACE INTO
>     gpkg_contents(table_name,data_type,identifier,min_x,min_y,max_x,max_y,srs_id)
>       SELECT
>         'marker_2019_cvr' AS table_name,
>         'features' AS data_type,
>         'marker_2019_cvr' AS identifier,
>         MIN(ST_MinX(geom)) AS min_x,
>         MIN(ST_MinY(geom)) AS min_y,
>         MAX(ST_MaxX(geom)) AS max_x,
>         MAX(ST_MaxY(geom)) AS max_y,
>         25832 AS srs_id -- same srs as the base layer for the view
>       FROM marker_2019_cvr;
>     -- insert or update gpkg_geometry_columns
>     INSERT OR REPLACE INTO gpkg_geometry_columns ( table_name,
>     column_name , geometry_type_name, srs_id, z, m)
>       VALUES ('marker_2019_cvr', 'geom', 'MULTIPOLYGON', 25832, 0, 0);
>     -- insert or update gpkg_ogr_columns (necessary ?)
>     INSERT OR REPLACE INTO gpkg_ogr_contents(table_name,feature_count)
>       SELECT
>         count(*) AS feature_count
>       FROM marker_2019_cvr;*
>     AFAIK, this is the necessary steps to make a spatial view visible
>     in a GeoPackage. And it works; sort of...
>     The QGIS datasource manager shows the view as a spatial table. I
>     can add it to the QGIS map, but... it can't find the CRS for the
>     layer and defaults to the projects CRS.
>     Digging a litle bit deeper: Using ogrinfo like this:
>     *ogrinfo -ro -so data_marker_vandloeb_soe.gpkg marker_2019_cvr*
>     shows the layers SRS WKT as (unknown).
>     Using the same command on the base layer *marker_2019 *gives the
>     correct WKT.
>     25832 is the correct EPSG number for the CRS. And the definition
>     exists in the *gpkg_spatial_ref_sys* table.
>     What am I doing wrong ? Or is it just "out of scope" for OGR ??
>     Med venlig hilsen / Best regards
>     Bo Victor Thomsen
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230528/5a19438a/attachment-0001.htm>
