[gdal-dev] WFS requests failing with /vsicurl/ against QGIS Server: missing Content-Length header
Jorge Gustavo Rocha jgr at osgeopt.pt
Mon May 29 15:23:24 PDT 2023
I'm getting errors with WFS calls to QGIS Server using /vsicurl/.
Against Geoserver I didn't notice this issue.
I can work on a solution, if the problem is on the QGIS Server side. I
would love to have a second opinion on this.
What I have found:
1) The is no Content-Length: header in QGIS Server answer:
curl -L -I
"https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5016"
HTTP/1.1 200 OK
Date: Mon, 29 May 2023 22:12:32 GMT
Server: Apache/2.4.41 (Ubuntu)
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: POST, GET, OPTIONS, DELETE, PUT
Access-Control-Max-Age: 1000
Access-Control-Allow-Headers: x-requested-with, Content-Type, origin,
authorization, accept, client-security-token
Content-Type: text/xml; subtype=gml/2.1.2; charset=utf-8
2) The is a Content-Length: header in Geoserver answer:
curl -L -I
"https://wssig3.azores.gov.pt/geoserver/ows?service=WFS&request=GetFeature&typename=ef:EnvironmentalMonitoringFacility&version=2.0.0&srsname=EPSG:5015"
HTTP/1.1 200 OK
X-Frame-Options: SAMEORIGIN
Content-Type: application/gml+xml; version=3.2
Content-Disposition: inline; filename=features.xml
Content-Length: 494599
Server: Jetty(9.4.18.v20190429)
Example of testing calls:
This works (without vsicurl):
ogrinfo
INFO: Open of
`https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5016'
       using driver `GML' successful.
1: ponto_cotado
This does not work:
ogrinfo
"/vsicurl/https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5016"
--debug on
HTTP: libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8
libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib
nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.14
VSICURL: HEAD did not provide file size. Retrying with GET
VSICURL:
GetFileSize(https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5016):
response_code=200, curl error msg=Failure writing output to destination
VSICURL: Request at offset 0, after end of file
VSICURL:
GetFileList(/vsicurl/https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin)
VSICURL:
GetFileSize(https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5011):
ogrinfo failed - unable to open
'/vsicurl/https://irig-madeira.pt/postgresql/drote/public/baram_2020/cgi-bin/qgis_mapserv.fcgi?service=WFS&version=2.0.0&request=GetFeature&typename=ponto_cotado&srsname=EPSG:5016'.
DGNv8: Driver cleanup
Using docker, I can not use /vsicurl/ with WFS too:
docker run -ti --rm osgeo/gdal ogrinfo
--debug on
nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.13
VSICURL:
VSICURL:
VSICURL:
For a Geoserver layer, vsicurl is working:
ogrinfo
INFO: Open of
`https://wssig3.azores.gov.pt/geoserver/ows?service=WFS&request=GetFeature&typename=ef:EnvironmentalMonitoringFacility&version=2.0.0&srsname=EPSG:5015'
1: EnvironmentalMonitoringFacility
Can I assume that the problem is the missing Content-Length header in
QGIS Server WFS answer? Should I file a bug about this in QGIS?
Regards,
Jorge
OSGeo Portugal
NIF: 509588190
email: geral at osgeopt.pt
https://www.osgeopt.pt/
Próximo evento: SASIG 2017, 20 a 22 de novembro, Porto
Mais informações: http://osgeopt.pt/sasig2017/
