[gdal-dev] tps - gdalwarp vs ogr2ogr
Andrew C Aitchison andrew at aitchison.me.uk
Tue Nov 7 06:22:26 PST 2023
https://raw.githubusercontent.com/craigshelley/QuickChart/master/Specification/The%20Quick%20Chart%20File%20Format%20Specification%201.03.pdf
describes a file format which includes polynomials describing forward
*and reverse* tranforms for this.
I don't know how common, or accurate, such reverse transforms are.
Would it be useful or much effort to add the ability to use the
reverse transform when it is offered ?
[ I have a gdal driver which can read some
  but not all of these files. ]
On Tue, 7 Nov 2023, Even Rouault via gdal-dev wrote:
> Hi,
> I've ticketed your issue as https://github.com/OSGeo/gdal/issues/8672 . What
> you could try to reduce the execution time is to enable multithreading by
> adding -wo NUM_THREADS=ALL_CPUS to your gdalwarp command line
> And yes the previous implementation of the raster TPS transformation was
> "wrong", at least not consistent with the forward direction of the TPS
> transformer as used by ogr2ogr. Both matched on the exact location of ground
> control points, but the result could be substantially different in-between.
> The new implementation solves that, but it implies substantial more
> computation cost as you found out...
> Even
> Le 07/11/2023 à 08:29, Stijn Tallir via gdal-dev a écrit :
>> Hi Jukka,
>> The transformation lasted 3h20min vs 9min (before the fix)!
>> The results for raster and vector tps transformation are very similar now
>> and nothing changed for the vector result. Do I have to conclude the
>> previous rasters tps transformation method was faulty then?
>> Stijn
>> Op ma 6 nov 2023 om 16:32 schreef Stijn Tallir <stijn+gdal-dev at strict.be
>> <mailto:stijn%2Bgdal-dev at strict.be>>:
>>     Hi,
>>     Does that mean the old raster tps transformation was "wrong" or
>>     the old vector transformation?
>>     I'm doing a test and trying to transform my raster image with the
>>     latest dev version in osgeo4W but it takes forever to process now.
>>     Don't know in how many days I will see the result :(
>>     The vector transformation with the latest dev version was the same
>>     (time and result).
>>     Stijn
>>     Op ma 6 nov 2023 om 14:48 schreef Rahkonen Jukka
>>     <jukka.rahkonen at maanmittauslaitos.fi>:
>>         Hi,
>>         See the issue https://github.com/OSGeo/gdal/issues/8572
>>         <https://github.com/OSGeo/gdal/issues/8572>. Maybe your
>>         problem is also resolved by
>>         https://github.com/OSGeo/gdal/pull/8573. The fix is included
>>         in the GDAL 3.8 RC1 version that was released 3 hour ago. Do
>>         you have an option to make a test?
>>         -Jukka Rahkonen-
>>         *Lähettäjä:* Stijn Tallir <stijn at strict.be>
>>         *Lähetetty:* maanantai 6. marraskuuta 2023 14.47
>>         *Vastaanottaja:* Rahkonen Jukka
>>         *Kopio:* gdal-dev at lists.osgeo.org
>>         *Aihe:* Re: [gdal-dev] tps - gdalwarp vs ogr2ogr
>>         Hi Jukka,
>>         I finally found the time to produce a test set.
>>         You can download it here:
>>         https://drive.google.com/file/d/1Y08Q-tIm5dxyKFKNdVqilvAO3H7FFFbx/view?usp=sharing
>>         I started from an unreferenced raster file (raster2tps.tif)
>>         with gcp's (gcp4tps.gcp) and transformed it with tps
>>         (tpsraster.tif).
>>         Then polygonized the unreferenced raster file (vector2tps.shp)
>>         and transformed the result with  the same gcp's (gcp4tps.gcp)
>>         and with tps (tpsvector.shp).
>>         The vector2tps.shp polygons are "flipped" because of the
>>         different Y-origin for rasters and vectors but this way both
>>         datasets can use the exact same gcp's.
>>         When you lay the tpsvector-result on top of the
>>         tpsraster-result (in QGis for instance) you'll see the
>>         differences in how both are transformed.
>>         Kind regards,
>>         Stijn
>>         Op wo 16 aug 2023 om 13:16 schreef Stijn Tallir
>>         <stijn+gdal-dev at strict.be <mailto:stijn%2Bgdal-dev at strict.be>>:
>>             Yes, I checked them visually for both raster and vector.
>>             I compared the results also visually. The rasters are
>>             transformed in a way that the end ponts of the gcp's align
>>             exactly with the result so that is why I referred to it as
>>             "right". The vector data result is in the neighbourhood of
>>             the end points (sometimes a rather significant distance).
>>             The result is different from order 1-3 transformations so
>>             I presume the tps option isn't ignored.
>>             Stijn
>>             Op wo 16 aug 2023 om 11:52 schreef Rahkonen Jukka
>>                 Hi,
>>                 Did you check the ground control points? What is your
>>                 reference when you say that one result is right, and
>>                 another wrong? Have you used some other software for
>>                 comparison? Or do you only know that the results are
>>                 different?
>>                 -Jukka-
>>                 *Lähetetty:* keskiviikko 16. elokuuta 2023 12.27
>>                 Hi Jukka,
>>                 I thought of the density as an option for the "error"
>>                 as you suggested and I made a point-file with a point
>>                 for every pixel in my original image and used this as
>>                 a source for the ogr2ogr transformation. So you could
>>                 say the desnity for both sources raster and vector)
>>                 are then alike.
>>                 The results were still the same (and wrong) ...
>>                 Stijn
>>                 Op wo 16 aug 2023 om 10:22 schreef Rahkonen Jukka
>>                     Hi,
>>                     Without test data it is very hard to say much. I
>>                     believe that the promise of tps is that the ground
>>                     control points stay where they are set. The
>>                     intermediate points follow the least tension
>>                     surfaces and I do not know how exactly those
>>                     spline algorithms are defined. Raster data is full
>>                     of points to warp but probably in the vector data
>>                     the transformation is done vertex by vertex. I
>>                     would first check if the GCPs are in the same
>>                     place in both outputs. Then I would make a test by
>>                     densifying the vector data before georeferencing
>>                     to have much more vertices and see if it has any
>>                     effect on the result.
>>                     -Jukka Rahkonen-
>>                     *Lähettäjä:* gdal-dev
>>                     <gdal-dev-bounces at lists.osgeo.org> *Puolesta
>>                     *Stijn Tallir
>>                     *Lähetetty:* keskiviikko 16. elokuuta 2023 10.29
>>                     *Vastaanottaja:* gdal-dev at lists.osgeo.org
>>                     *Aihe:* [gdal-dev] tps - gdalwarp vs ogr2ogr
>>                     Hi,
>>                     According to the documentation gdal and ogr use
>>                     the same algorithm for the tps-transformation but
>>                     I don't seem to get the same results using the
>>                     same set of gcp's for images and vectors.
>>                     I have images that are unreferenced and vector
>>                     data digitised on these images (in pixel coordinates).
>>                     The images are then georeferenced with +100 gcp's
>>                     and warped with gdalwarp using the "tps" option.
>>                     When I use the same gcp's (with adjusted y-origin
>>                     to lower left corner) to georeference the vector
>>                     data with ogr2ogr and the "tps" option I get
>>                     different results. The vector-result is similar to
>>                     the image-result but never exactly the same and
>>                     differences can be substantial.
>>                     Any thoughts?
>>                     Stijn
>>                 Stijn Tallir - StrICT BV
>>                 Wijnveld 8
>>                 9112 Sinaai-Waas
>>                 GSM: 0486 750220
>>                 E-mail: Info at strict.be
>>                 Web: www.strict.be <http://www.strict.be/>
>>                 BTW: BE 0567.559.668
>>         Wijnveld 8
>>         9112 Sinaai-Waas
>>         GSM: 0486 750220
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
Andrew C. Aitchison                      Kendal, UK
