[gdal-dev] Transforming from EPSG:29902 to EPSG:4326 at the limit of the area of use.
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Nov 8 05:47:59 PST 2023
Assuming that it does not happen in the main area of Ireland...I guess it
is because it is outside of the area of usage of the datum transformation
https://epsg.org/transformation_1641/TM65-to-WGS-84-2.html
Probably (this is just a guess) gdalwarp is not taking it into
consideration, making a ballpark transformation between TM65 and WGS84,
while ogr2ogr doesn't.
On Wed, 8 Nov 2023 at 13:35, Sam Hall via gdal-dev <gdal-dev at lists.osgeo.org>
wrote:
> I have some data that covers the whole of the Republic of Ireland,
> including the Blasket Islands off the West Coast, situated around 24439,
> 95540 in EPSG:29902. These islands straddle the western boundary of the
> area of use of the coordinate system -10.56° W.
> When transforming a raster dataset from EPSG:29902 to EPSG:4326 using
> gdalwarp at gdal >= 3.5.2, there seems to be a roughly 50 m shift in the
> data at the area of use boundary, while if I use ogr2ogr on a vector copy
> of this data, I don't see this shift.
> I have a reproducible example of this at
> https://gitlab.com/Sam.Hall1/29902_gdalwarp_vs_ogr2ogr.git. In this
> example I created a rectangular polygon with interpolated points and saved
> it to a shapefile, then used gdal_rasterize to create a GeoTiff. gdalwarp
> gives the desired result using a gdal 3.5.1 docker image. The full commands
> are in the docker-compose.yml in the repository but the parameter's I'm
> using are:
> gdalwarp -t_srs EPSG:4326 -tr 0.000045 0.000045 -tap -overwrite input.tif
> output.tif
> ogr2ogr -t_srs EPSG:4326 output.shp input.shp
> I've also seen similar results when transforming from EPSG:27700 to
> EPSG:4326 in Jersey and Guernsey in the English Channel but I'd have to use
> a much earlier version of gdal to reproduce the desired result.
> Is there a gridshift file or any additional parameters that I could use to
> get the output to look more continuous across the area of use line?
> Sam
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231108/077eb1cb/attachment.htm>
