[gdal-dev] Fwd: oblique cuts on a raster using python GDAL
Naima Dambrine naima.etienne at gmail.com
Thu Nov 9 04:40:32 PST 2023
Hi Laurentiu,
Thank you, I think I'm not concerned because I use GTiff format as output,
then I specify a deflate compression with predictor=2 and zlevel=9.
Please, tell me if it is correct or not.
Naïma
Le mer. 8 nov. 2023 à 15:41, Laurențiu Nicola <lnicola at dend.ro> a écrit :
> Hi Naïma,
> I'm a bit late to the party, but note that the JP2OpenJPEG produces lossy
> output by default. You need to pass REVERSIBLE=YES and QUALITY=100 as
> creation options to make it use lossless compression.
> Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231109/9452a4d9/attachment.htm>
