[gdal-dev] Export image binary data from GDB dataset
andy aborruso at gmail.com
Wed Nov 15 03:49:37 PST 2023
I have a Binary field in a GDB data source.
I have no other metadata about it. I know only that the field name is
"image", then it should contain images.
But I do not know the original file format.
I have extract one row (and then one field) as string it, using
ogr2ogr -f CSV /vsistdout/ -fieldTypeToString Binary data.gdb SITI_ARCHEO
-where "OBJECTID=277" >out.csv
And I have a long string as the one below.
I have tried to use "xxd -r -p" to convert to binary and then use "file" to
interpret its file format, but I don't get anything useful.
How could I do some reverse extraction of these images in their original
format?
Thank you
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
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231115/8c639a9b/attachment.htm>
