[gdal-dev] Problems compiling in Mac
Even Rouault even.rouault at spatialys.com
Thu Nov 23 06:01:38 PST 2023
Le 23/11/2023 à 14:53, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> A colleague of mine is compiling in Mac. I am aware of the problems
> with arrow and libkml:
> https://gdal.org/development/building_from_source.html#building-on-macos
> But we are compiling with GDAL_USE_EXTERNAL_LIBS=OFF
> However he has those problems with arrow and libkml, and had to
> unistall them from his computer.
> I thought that it was enough disabling GDAL_USE_EXTERNAL_LIBS (we are
> not enabling explicitly arrow or kml). Am I wrong?
He might have to remove CMakeCache.txt because it could contain the
GDAL_USE_LIBKML=ON declaration that was set before turning off
> Thanks.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231123/413d154a/attachment.htm>
