[gdal-dev] "RFC 98: Build requirements for GDAL 3.9" available for review
Kurt Schwehr schwehr at gmail.com
Fri Nov 24 15:25:01 PST 2023
Woohoo! I look forward to the cleanups that this will enable.  Thank you
Even for working on this!
I am hoping that the hdf4 will get some similar improvements in 2024. I
haven't looked to see if any of the hdf4 cleanup in 2023 could allow GDAL
cleanup. My guess is that there isn't anything yet as most of the changes
have been internal only.
On Fri, Nov 24, 2023 at 3:15 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> Please find "RFC 98: Build requirements for GDAL 3.9" in
> https://github.com/OSGeo/gdal/pull/8802 for review & comments
> Summary:
> The document updates RFC68 with the new build requirements for GDAL 3.9:
>    - C++ >= 17
>    - CMake >= 3.16
>    - PROJ >= 6.3.1
> The minimum version for the following optional dependencies is also
> updated:
>    - Python >= 3.8
>    - GEOS >= 3.8
>    - Poppler >= 0.86
>    - libtiff >= 4.1
>    - libcurl >= 7.68
>    - libpng >= 1.6.0
>    - libsqlite3 >= 3.31
>    - libopenjp2 >= 2.3.1
>    - libnetcdf >= 4.7 and built with NC4 enabled
>    - libhdf5 >= 1.10
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231124/8f312824/attachment.htm>
