[gdal-dev] slow translate with OVERVIEW_LEVEL=NONE when no overviews exist
Scott public at postholer.com
Fri Nov 24 16:51:02 PST 2023
Over the network it takes 23 seconds:
time gdal_translate -oo OVERVIEW_LEVEL=NONE -outsize 219 226
/vsicurl/https://github.com/mdsumner/cog-example/raw/main/cog/sentinel-image.tif
net.tif
real  0m23.909s
user  0m4.374s
sys   0m1.021s
Saving the file locally and translating it's fractional second:
time gdal_translate -oo OVERVIEW_LEVEL=NONE -outsize 219 226 sent.tif
local.tif
real  0m0.143s
user  0m0.107s
sys   0m0.036s
My guess is there are numerous reads of the file and across a network,
depending on server load, etc, it may take muchlonger.
On 11/24/23 15:44, Michael Sumner via gdal-dev wrote:
> When I translate this GeoTIFF to 10% original size, it's very very slow
> if OVERVIEW_LEVEL=NONE is set.
> The GeoTIFF has no overviews.
> export
> dsn="/vsicurl/https://github.com/mdsumner/cog-example/raw/main/cog/sentinel-image.tif <https://github.com/mdsumner/cog-example/raw/main/cog/sentinel-image.tif>"
> ## takes *forever*
> gdal_translate $dsn  out.tif -outsize 219 226 -oo OVERVIEW_LEVEL=NONE
> ## works fast as expected
> I found this in a package that has a global open option setting for
> overviews for subsampling with RasterIO(). There we could detect that
> overviews are not present, or even just not set it at all ... (better to
> use GDALwarp() for general cases IMO).
> But, is there a good reason why setting that open option affects
> translate for sources with no overviews?
> I'm in master at ebac6b74a429fa6eeeb94edd074b6cb60072a35f
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com <mailto:mdsumner at gmail.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
