[gdal-dev] Creation of MVT vector tiles with fid
Even Rouault even.rouault at spatialys.com
Sat Nov 25 06:14:26 PST 2023
add -preserve_fid to your ogr2ogr command line. On reading, you'll see
it in the mvt_id field (on reading it is not set as a OGR feature id,
since a given OGR feature can be split among several tiles, leading to
several features when reading back, hence it is exposed as an attribute
field to make sure the unicity of the OGR feature id)
Even
Le 25/11/2023 à 14:47, OpenDEM via gdal-dev a écrit :
> Can someone please tell me how to prepare the data for the creation of
> MVT vector tiles with a fid?
> ogr2ogr -f MVT outputfolder input.geojson (or PostGIS or ...) -dsco
> MINZOOM=0 -dsco MAXZOOM=6 -dsco COMPRESS=NO
> Best regards,
> Martin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
