[gdal-dev] Is the SOSI Norwegian driver still useful?
Even Rouault even.rouault at spatialys.com
Sat Nov 25 09:25:15 PST 2023
I got feedback from a user
(https://mastodon.social/@lenas@fosstodon.org/111470467316641321) that
the driver is apparently still usable for some datasets that can be
downloaded from the national map catalog
(https://kartkatalog.geonorge.no<https://kartkatalog.geonorge.no>). So I
guess we'll have to keep it alive for now. But the Norwegian community
would be most welcome to step up to maintain it to address its shortcomings.
Even
Le 23/11/2023 à 18:00, Even Rouault via gdal-dev a écrit :
> Hi,
>> However, I doubt that these organisations use the SOSI driver from
>> GDAL/OGR to produce these files.
> They can't: the driver is read-only
> Discussing that topic with other developers today during GDAL
> maintainer meeting, we could proceed with how we did in the past with
> drivers we suspected to be no longer used but lacked data points. That
> is in 3.9 the driver will be still there, but when it detects a SOSI
> dataset, it will error out with a message indicating to the user that
> they have to define an environment variable to enable it, and invite
> them to file an issue on the bug tracker to make a case for keeping
> the driver, otherwise without feedback, the driver will be fully
> removed in 3.10
> Dan also pointed to that QGIS ticket
> (https://github.com/qgis/QGIS/issues/50868) where a user reported a
> crash when trying to use a SOSI file, showing that there are issues in
> the driver and/or libfyba.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231125/33d24240/attachment-0001.htm>
