[gdal-dev] [External] : Re: GDAL driver Open() calls
Even Rouault even.rouault at spatialys.com
Thu Nov 30 12:41:43 PST 2023
ok, that should be fixed per https://github.com/OSGeo/gdal/pull/8885
(and factorization of similar code of gdal_translate_lib.cpp and
gdaldriver.cpp)
Le 30/11/2023 à 20:59, Fengting Chen a écrit :
> Hi Even,
> Here is what found out from debugging: There are two Open() calls.
> Your fix skipped one. Here is the stack trace of the second one:
> Thanks!
> *From: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Thursday, November 30, 2023 at 8:40 AM
> Le 30/11/2023 à 04:47, Fengting Chen a écrit :
>     This doesn’t seem to fix the problem. How do I print out the stack
>     trace in the driver?
> This is not something the driver can do. You have to use the
> interactive debugger of your dev environment, attach it to your
> gdal_translate command, set a breakpoint in the GeoRasterDataset::Open
> method, and use the appropriate function of your debugger to display
> the call stack. I'm sure you'll find plenty of online resources for
> whatever debugger you use.
> Even
> http://www.spatialys.com  <https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!LdunXkjoOPFddx-jqp6_eWkk746TTCmRdAPcBj35cB2LBYcxMogtL6zHZEup8CJ2DN0T62IvlW7uYshKVkU9PsDwZbPE$>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231130/ff9e85a9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231130/ff9e85a9/attachment-0001.png>
