[gdal-dev] VSIGetMemFileBuffer Returns NULL When Copying Vector Dataset to Vsimem
    Even Rouault
    even.rouault at spatialys.com
    Wed Oct  4 03:09:38 PDT 2023
size_t is an incorrect size for DataLength (if you run on 32 bit
architecture). You should use vsi_l_offset.
Besides that the following standalone inspired from your code works fine
for me:
#include <stdio.h>
#include "gdal_priv.h"
int main()
     GDALAllRegister();
     GDALDataset* Dataset
=GDALDataset::FromHandle(GDALOpenEx("poly.shp", GDAL_OF_VECTOR |
GDAL_OF_VERBOSE_ERROR, nullptr, nullptr, nullptr));
     GDALDataset* Copy =
Dataset->GetDriver()->CreateCopy("/vsimem/foo.shp", Dataset, false,
nullptr, nullptr, nullptr); //appears to produce a valid Dataset
containing the same layers & features as its source.
     GDALClose(Dataset);
     GDALClose(Copy);
     vsi_l_offset DataLength = 0;
     GByte* Buffer = VSIGetMemFileBuffer("/vsimem/foo.shp", &DataLength,
true);
     printf("%p %d\n", Buffer, int(DataLength)); // buffer not null and
DataLength > 0
     CPLFree(Buffer);
     VSIUnlink("/vsimem/foo.dbf");
     VSIUnlink("/vsimem/foo.shx");
     return 0;
Even
Le 04/10/2023 à 06:26, Soren Saville Scott via gdal-dev a écrit :
> Hi,
> I'm integrating GDAL in C++ with a system that defines its own asset
> types stored on disk, and am writing a wrapper for datasets using this
> asset system. To 'import' a dataset I call GDALOpenEx on it,
> CreateCopy() it to some "/vsimem/foo.shp" path, GDALClose() the
> datasets to flush it, and call VSIGetMemFileBuffer with
> bUnlinkAndSeize=true to take ownership of the underlying memory buffer.
> GDALDataset* Dataset = GDALOpenEx("foo.shp", GDAL_OF_VECTOR |
> GDAL_OF_VERBOSE_ERROR, nullptr, nullptr, nullptr);
> GDALDataset* Copy =
> GDALClose(Dataset);
> GDALClose(Copy);
> size_t DataLength;
> true); //<-- returns NULL
> For some reason VSIGetMemFileBuffer always fails, returning a nullptr.
> This is basically identical to a similar problem I had, described
> here: https://stackoverflow.com/questions/73644157/get-raw-buffer-for-in-memory-dataset-in-gdal-c-api
> <https://stackoverflow.com/questions/73644157/get-raw-buffer-for-in-memory-dataset-in-gdal-c-api> which
> I never really found a solution to. I have similar issues with other
> VSI functions, e.g. calling GDALOpenEx on a path created by
> VSIFileFromMemBuffer also fails.
> Any idea as to what the problem is here?
> Alternatively, maybe there's a better way to 'emplace' datasets inside
> some other file?
> Thanks,
> Soren Saville Scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231004/49a3117c/attachment-0001.htm>
