[gdal-dev] format for topology?
Even Rouault even.rouault at spatialys.com
Mon Oct 9 13:04:56 PDT 2023
Michael,
you won't find much support for that in GDAL itself. You'd better have a
look at Spatialite topology, PostGIS topology or GRASS topology. The
process is basically: import your geometries as a topology,  do
reprojection or other work in the topology domain, and go back to the
geometry domain.
QGIS has a plugin to work with PostGIS topology:
https://plugins.qgis.org/plugins/pgtopoeditor/
(I was involved in discussions yeaaars ago about having GDAL offering a
generic API and translation between all those topology formats but that
never materialized)
Even
Le 09/10/2023 à 21:55, Michael Sumner via gdal-dev a écrit :
> Are there any formats that record "coverage" topology? What I'm
> worried about is when shapes are encoded as blob geometry with
> initially identical  coordinates at shared vertices, is there any
> process that can validate or record that particular coords should have
> the same values even after reprojection or decomposition/rebuild?
> I know how to do this in custom ways, I'm hoping to find some
> off-the-shelf process to at least refer to (I'm a bit pressed for time
> so I'm asking without doing the extra homework that's needed).  I
> would build an indexer of the unique coordinates and how they relate
> to the blob geometries before and after and do checks there, but I
> don't know of an existing process that guarantees this.
> I understand that precision-setting is used to prevent numeric loss,
> but is there any formalization about that loss? (i.e.  different
> instances of a vertex really do stay unique). I guess the result is
> going to be pretty good if you choose the precision appropriately and
> modifications aren't extreme?
> Thanks for consideration!
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
