[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Thu Oct 12 01:27:05 PDT 2023
Hi Javier,
I've come across some other bugs that are specific to Conda running in
Pycharm only this morning. Up to and including getting different
projection strings back for the exact same file, depending on whether
the `GetProjectionRef` is called via Pycharm or the terminal (using the
exact same conda environment).
`osr.SpatialReference().ImportFromEPSG(4326)` returns a RuntimeError in
Pycharm but works in the terminal:
PROJ: proj_create_from_database: Open of
/some/path/anaconda3/envs/abc/share/proj failed
So there's something weird going on with environment's that's Posix
specific.
Thanks,
Jonathan
On 2023-10-12 09:10, Javier Jimenez Shaw wrote:
> Are you running pycharm under the conda environment? If you lose any
> setting while combining both it can be a problem.
> Have you tried setting PROJ_DEBUG=3 ?
> It will show some traces from PROJ, like the location of proj.db used.
> The point is if you can see the std out.
> On Wed, 11 Oct 2023, 15:18 Jonathan Moules via gdal-dev,
> <gdal-dev at lists.osgeo.org> wrote:
>     Hi List,
>     So, after more investigation:
>     * Using Python Anaconda on either Mac or Linux for GDAL (3.7.1),
>     `GetSpatialRef` triggers a RunTime Error for all shapefiles (but only
>     shapefiles).
>     * This happens on Ubuntu (two machines), and a Mac, but only under
>     PyCharm.
>     * Using the exact same `conda` environment as triggers the above:
>     running it directly from the terminal works fine.
>     So there's something about the combination of conda and Pycharm that
>     breaks this aspect of GDAL shapefile handling on *nix and Mac.
>     Any thoughts? Also, who do I actually report this bug to? Is it GDAL,
>     Conda, Pycharm, something else?
>     Cheers,
>     Jonathan
>     On 2023-09-28 14:58, Jonathan Moules via gdal-dev wrote:
>     > Well, it seems that PROJ_DATA isn't set in their environment.
>     But it's
>     > not set in mine either (`print(os.environ['PROJ_DATA']`)! So no
>     idea
>     > why mine works just fine without it (Windows 11 thing?).
>     > Creating a PROJ_DATA env var didn't fix anything. Even adding it
>     > explicitly in Python.
>     > Their log file does have this in at a WARNING level:
>     > `PROJ: proj_create_from_database: Open of
>     > /home/user/anaconda3/envs/env1/share/proj failed`
>     > That path has: `drwxrwxr-x` permissions.
>     > To answer Even's earlier question:
>     > `ogrinfo /path/to/shape.shp` works fine on their system.
>     > On 2023-09-28 12:37, Rahkonen Jukka wrote:
>     >> Hi,
>     >> Then they should add that environment if they do not know that
>     they
>     >> do not belong to "most users"
>     >> https://proj.org/en/9.3/usage/environmentvars.html
>     >> -Jukka Rahkonen-
>     >> -----Alkuperäinen viesti-----
>     >> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta
>     >> Lähetetty: torstai 28. syyskuuta 2023 14.10
>     >> Vastaanottaja: gdal-dev at lists.osgeo.org; Even Rouault
>     >> <even.rouault at spatialys.com>
>     >> Aihe: Re: [gdal-dev] layer.GetSpatialRef() fails on linux for
>     shapefiles
>     >> Hi Even,
>     >> The colleague doesn't have either a PROJ_LIB or a PROJ_DATA
>     >> environment variable.
>     >> I asked another colleague to try it; they're on Ubuntu 20.04,
>     and it
>     >> worked for them. I believe using the same setup instructions.
>     >> Cheers,
>     >> Jonathan
>     >> On 2023-09-24 22:37, Jonathan Moules via gdal-dev wrote:
>     >>> Thanks Even. I don't have access to the machine either as the
>     >>> colleague is moving to another project. I'll have to see if it
>     fails
>     >>> for another *nix user.
>     >>> On 2023-09-24 22:35, Even Rouault wrote:
>     >>>> Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
>     >>>>>> Also check if the environment isn't messed up regarding
>     PROJ and
>     >>>>> the PROJ_LIB/PROJ_DATA environment variable
>     >>>>> Thanks Even; sorry, what does this line mean? I'm guessing
>     you're
>     >>>>> referring to:
>     >>>>> https://proj.org/en/9.3/usage/environmentvars.html - what
>     would a
>     >>>>> "messed up" one look like?
>     >>>> Hard to say without access to the machine. Perhaps just try to
>     >>>> recreate a new Conda env from scratch
>     >>> _______________________________________________
>     >>> gdal-dev mailing list
>     >>> https://list/
>     >>> s.osgeo.org
>     <http://s.osgeo.org>%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7Cjukka.rahko
>     >>> nen%40maanmittauslaitos.fi
>     <http://40maanmittauslaitos.fi>%7C1f6517888cb34fa40aed08dbc01389dd%7Cc4f8a6
>     3255804a1c92371d5a571b71fa%7C0%7C0%7C638314962370381350%7CUnknown%7CTW
>     FpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6
>     Mn0%3D%7C3000%7C%7C%7C&sdata=3fVru6K6Ndpkv35FnAbMOlT%2BM96USO7wywqx550
>     >>> uRUs%3D&reserved=0
>     >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231012/eab148c8/attachment.htm>
