[gdal-dev] Writting a shapefile from C++ API: case a field of the OFTReal type
Roland Baviere roland.baviere at districtlab.eu
Sat Oct 14 07:16:42 PDT 2023
Hi all,
I've just found that a declaration of this type solved my problem:
OGRFieldDefn oField( "Val dbl", OFTReal );
// oField.SetWidth(64);
I have no idea why.
I suggest that the tutorial is updated to reflect this (common) case.
Kind regards,
Roland
Le sam. 14 oct. 2023 à 16:12, Roland Baviere <roland.baviere at districtlab.eu>
a écrit :
> Dear Community,
> I hope this e-mel finds you well.
> I am trying to write a shaprfile from a C++ application (windows),
> following the tutorial found here:
> https://gdal.org/tutorials/vector_api_tut.html#writing-to-ogr
> Everything works fine except for Fields of the OFTReal type, which are
> systematically truncated in the produced shapefile, as if they were
> declared as integer.
> The example illustrates the declaration of a string type:
> OGRFieldDefn oField( "Name", OFTString );
> oField.SetWidth(32);
> I tried to adapt it to the case were I want to serialize a field of the double type:
> but the aforementionned truncation error occurs.
> What am I doing wrong?
> Thanks a lot for your help and time.
> Kind regards,
> Roland BAVIERE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231014/e8ed7aff/attachment.htm>
