[gdal-dev] Performance regression testing/benchmarking for CI
Javier Jimenez Shaw j1 at jimenezshaw.com
Sun Oct 15 04:34:24 PDT 2023
Hi Even. Thanks, it sounds good.
However I see a potential problem. I see that you use once "SetCacheMax".
We should not forget about that in the future for sensible tests. The cache
of gdal is usually a percentage of the total memory, that may change among
the environments and time.
On Wed, 11 Oct 2023, 07:53 Laurențiu Nicola via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> No experience with pytest-benchmark, but I maintain an unrelated project
> that runs some benchmarks on CI, and here are some things worth mentioning:
>  - we store the results as a newline-delimited JSON file in a different
> GitHub repository (
> https://raw.githubusercontent.com/rust-analyzer/metrics/master/metrics.json,
> warning, it's a 5.5 MB unformatted JSON)
>  - we have an in-browser dashboard that retrieves the whole file and
> displays them: https://rust-analyzer.github.io/metrics/
>  - we do track build time and overall run time, but we're more interested
> in correctness
>  - the display is a bit of a mess (partly due to trying to keep the setup
> as simple as possible), but you can look for the "total time", "total
> memory" and "build" to get an idea
>  - we store the runner CPU type and memory in that JSON; they're almost
> all Intel, but they do upgrade from time to time
>  - we even have two AMD EPYC runs, note that boost is disabled in a
> different way there (we don't try to disable it, though)
>  - we also try to measure the CPU instruction count (the perf counter),
> but it doesn't work on GitHub and probably in most VMs
>  - the runners have been very reliable, but not really consistent in
> performance
>  - a bigger problem for us was that somebody actually needs to look at the
> dashboard to spot any regressions and investigate them (some are caused by
> external changes)
>  - in 3-5 years we'll probably have to trim down the JSON or switch to a
> different storage
> Laurentiu
> On Tue, Oct 10, 2023, at 21:08, Even Rouault via gdal-dev wrote:
> > Hi,
> > I'm experimenting with adding performance regression testing in our CI.
> > Currently our CI has quite extensive functional coverage, but totally
> > lacks performance testing. Given that we use pytest, I've spotted
> > pytest-benchmark (https://pytest-benchmark.readthedocs.io/en/latest/)
> as
> > a likely good candidate framework.
> > I've prototyped things in https://github.com/OSGeo/gdal/pull/8538
> > Basically, we now have a autotest/benchmark directory where performance
> > tests can be written.
> > Then in the CI, we checkout a reference commit, build it and run the
> > performance test suite in --benchmark-save mode
> > And then we run the performance test suite on the PR in
> > --benchmark-compare mode with a --benchmark-compare-fail="mean:5%"
> > criterion (which means that a test fails if its mean runtime is 5%
> > slower than the reference one)
> >  From what I can see, pytest-benchmark behaves correctly if tests are
> > removed or added (that is not failing, just skipping them during
> > comparison). The only thing one should not do is modify an existing test
> > w.r.t the reference branch.
> > Does someone has practical experience of pytest-benchmark, in particular
> > in CI setups? With virtualization, it is hard to guarantee that other
> > things happening on the host running the VM might not interfer. Even
> > locally on my own machine, I initially saw strong variations in timings,
> > which can be reduced to acceptable deviation by disabling Intel
> > Turboboost feature (echo 1 | sudo tee
> > /sys/devices/system/cpu/intel_pstate/no_turbo)
> > Even
> > http://www.spatialys.com
> > My software is free, but my time generally not.
> > gdal-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231015/be7bad63/attachment-0001.htm>
