[gdal-dev] GDAL Maintainers Meeting Minutes
Howard Butler howard at hobu.co
Tue Oct 31 14:18:53 PDT 2023
Howard Butler, Even Rouault, Dan Baston, and Alessandro Pasotti canceled the monthly GDAL Maintainers Meeting that was to be held on 10/26/2023 due to vacation and FOSS4GNA conflicts. Maintainers instead provided text updates which I am relaying as our monthly report.
Fundraising update
FrontierSI has declined to renew its Bronze sponsorship. More renewal traffic is expected in the next few months as we work to finish this year's cycle.
OSGeo Community Sprint
Howard Butler, Even Rouault, Jukka Rahkonen, and Dan Baston are currently signed up to attend the OSGeo Community Sprint next week in Vienna https://wiki.osgeo.org/wiki/OSGeo_Community_Sprint_2023 GDAL PSC members can obtain travel grants through the sponsorship program if they wish to attend (contact me for info).
Maintenance activities update
Status from Dan:
> * Fixed a bug in /vsimem that was causing some tests to not clean up after themselves.
> * Fixed more Python bindings crashes as a result of test execution independence effort.
Status from Alessandro:
> This month I reviewed a few PRs (mainly from Even):
> https://github.com/OSGeo/gdal/pull/8534
> https://github.com/OSGeo/gdal/pull/8531
> https://github.com/OSGeo/gdal/pull/8529
> https://github.com/OSGeo/gdal/pull/8526
> https://github.com/OSGeo/gdal/pull/8521
> https://github.com/OSGeo/gdal/pull/8519
> https://github.com/OSGeo/gdal/pull/8518
> https://github.com/OSGeo/gdal/pull/8516
> https://github.com/OSGeo/gdal/pull/8495
> Then I focused on investigating and fixing the following bugs:
> https://github.com/OSGeo/gdal/issues/8525 OpenCL always uses first
> device per platform on Mac
> https://github.com/OSGeo/gdal/issues/8523 Error in
> gdal.VectorTranslate for explodecollections=True + some weird python
> logging behaviour
> https://github.com/OSGeo/gdal/issues/8522 OAPIF: Increase the default page size
> Lastly, starting from a QGIS upstream issue
> https://github.com/qgis/QGIS/issues/54966 I worked on the GDAL side of
> the problem and wrote a test https://github.com/OSGeo/gdal/pull/8609,
> while investigating the issue I discovered another issue which was
> eventually fixed by Even with https://github.com/OSGeo/gdal/pull/8582
Status from Even:
> - Regeneration of GDAL 3.7.2 Docker images for WebP and curl recent CVEs
> - Add OGRLayer::WriteArrowBatch() functionality which is the write-side of RFC86, with a generic implementation for all drivers and specialized implementations for Arrow/Parquet:https://github.com/OSGeo/gdal/pull/8517- and use it in ogr2ogr when possible, that is when the source layer declares OLCFastGetArrowStream to give significant speed-ups (including for GeoPackage->GeoPackage): https://github.com/OSGeo/gdal/pull/8544 +https://github.com/OSGeo/gdal/pull/8560 . Note that is currently only enabled with a very restricted set of ogr2ogr options (mostly only -spat, -where and driver creation options)
> - Massive speed-up of GeoPackage spatial index creation. From 26 seconds down to 6 seconds on a 3.2 million feature table. https://github.com/OSGeo/gdal/pull/8596 . Also available as a separate library that can be used by non-GDAL implementations (libspatialite for example)
> - Significant performance improvement of RasterIO() on VRT with VRTComplexSource that have only a <NODATA> element and data types Byte/UInt16/Int16: https://github.com/OSGeo/gdal/pull/8562
> - CI: addition of (an embryo of) a performance regression test suite. Note that due to CI virtual machines being quite unpredictable performance-wise, it can only detect regressions > 20%. https://github.com/OSGeo/gdal/pull/8538
> - and ~50 other activities: bug fixes, pull request reviews
The next GDAL Maintainers Meeting is 11/23/2023 at 9:00 EDT. Any PSC members are welcome to join by reaching out to me for an invite.
Howard
