[gdal-dev] sqlite dialect: OpenFileGDB and FID Column selection
Even Rouault even.rouault at spatialys.com
Fri Sep 1 08:55:32 PDT 2023
in https://github.com/OSGeo/gdal/pull/8301, I've added the capability to
select/filter using the FID column name (when it is not empty) with the
SQLite dialect as well.
The behaviour of OGR SQL regarding FID use is documented at
https://gdal.org/user/ogr_sql_dialect.html#fid , and for the SQLite
dialect at https://gdal.org/user/sql_sqlite_dialect.html#feature-id
Even
Le 01/09/2023 à 10:28, Rahkonen Jukka a écrit :
> Hi,
> Feature IDs are confusing. Some formats require FID, some do not
> directly support FID at all (shapefile). Sometimes FID must be an
> integer, sometimes it is always a string (gml_id), and sometimes it is
> either or (GeoJSON). Ogr2ogr has 3 parameters for FIDs, and vector
> drivers add their own options. Primary key acts usually as a FID, but
> can a composite PK be a FID? FIDs are really meant for the machines
> and GDAL usually hides FIDs, but they may be meaningful also for
> humans as well and sometimes users would like to expose them as a
> normal attribute with tricks like SELECT *, fid_field as my_fid.
> I agree that something like a dedicated wiki page about FIDs in GDAL
> would be nice to have. Maybe documenting how OBJECTID in FileGDB
> behaves with different SQL dialects is a rather small detail to be
> documented separately.
> -Jukka Rahkonen-
> *Lähettäjä:* andy <aborruso at gmail.com>
> *Lähetetty:* perjantai 1. syyskuuta 2023 9.54
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Kopio:* gdal dev <gdal-dev at lists.osgeo.org>
> *Aihe:* Re: [gdal-dev] sqlite dialect: OpenFileGDB and FID Column
> selection
> Hi Jukka,
> On Fri, 1 Sept 2023 at 07:42, Rahkonen Jukka
> <jukka.rahkonen at maanmittauslaitos.fi> wrote:
>     When the SQLite dialect is used, a temporary SQLite database is
>     created. OBJECTID is a feature identifier (FID) and I guess that
>     the FID gets converted into a primary key with the SQLite
>     defaults. So maybe you can find the OBJECTID from ROWID.
> it works, thank you very much.
> Maybe a little related note in the documentation would do. What do you
> think about it?
> Thank you again
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230901/c1113a5d/attachment.htm>
