[gdal-dev] Memory mapped VSILFILE ?
Even Rouault even.rouault at spatialys.com
Tue Sep 5 00:40:48 PDT 2023
Andrew,
cf CPLVirtualMemFileMapNew() (
https://gdal.org/doxygen/cpl__virtualmem_8h.html#a02ab08b2cf138fa69d076ccd81eda3cb
) which was an implementation step of
https://gdal.org/development/rfc/rfc45_virtualmem.html
RawRasterBand::GetVirtualMemAuto()
(https://github.com/OSGeo/gdal/blob/83425621471d4987087317999d6fff3a482da88f/gcore/rawdataset.cpp#L1522)
may be of interest
Even
Le 05/09/2023 à 08:39, Andrew C Aitchison a écrit :
> Drivers work with VSILFILE objects.
> Sometimes these are real files but as I understand it,
> sometimes these are actually blocks of memory behind a file interface.
> Is the reverse possible, ie can I mmap a VSILFILE and then
> read it as if it were a block of memory ?
> This would be for read-only drivers.
> There will inevitably be endian issues, but I have come across
> several file formats that look to me to be designed to be read
> this way, especially the header structures.
> Thanks,
http://www.spatialys.com
