[gdal-dev] Formalizing GDAL "file name" syntax in an RFC?
Sean Gillies sean.gillies at gmail.com
Fri Sep 15 08:52:09 PDT 2023
Hi Alessandro,
On Fri, Sep 15, 2023 at 8:31 AM ElPaso <elpaso at itopen.it> wrote:
> Il 14/09/23 17:14, Sean Gillies ha scritto:
> > Hi all,
> > In https://github.com/OSGeo/gdal/pull/8155#issuecomment-1704923263 I
> > think I see (for the first time?) the beginning of a specification of
> > the syntax for GDAL "file names". I think it would be helpful if there
> > was an RFC for this.
> > I'm sure a lot of applications construct GDAL file names without much
> > understanding of what's correct or incorrect. A formal spec could help
> > make it more likely that anyone can construct a valid filename on the
> > first try.
> > A stretch goal for the RFC could be to come up with a syntax that is
> > sufficiently general that authors of new format drivers don't have to
> > create their own new idiosyncratic file names.
> Hi Sean,
> I totally agree that it would be useful to have a formally defined
> syntax to describe data sources, we have the same problem with QGIS
> QgsDataSourceUri and we are treating the URIs as a private
> implementation detail, but in QGIS we have a GUI to set the data source
> strings that partially mitigatest the issue.
> We discussed a few times what it could be the best format to encode a
> data source and URL encoding is probably a good candidate because it's
> well known and well supported by libraries.
> Maybe something like:
> <driver_name>://<path|connection>/<arguments ...>
> mssql://username:password@hostname:port/?table=table_name&arg1=arg1...
> gpkg:///path/to.gpkg?table=table_name&arg1=arg1...
> postgis://username:password@hostname:port/?table=table_name&arg1=arg1...
> shapefile:///path/to.shp/?arg1=arg1...
Yes, something like this is my dream :) I started working on such a
proposal a while back and then was derailed by a job change. I might try to
dust it off and start writing on it again.
I think the "vrt://" URI scheme was a mistake, though, and that we
shouldn't extend it to dozens of other formats. At least not without
consulting with other software communities. Ideally these schemes would be
universal across the internet.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230915/73b1c19f/attachment-0001.htm>
