[gdal-dev] Formalizing GDAL "file name" syntax in an RFC?
Even Rouault even.rouault at spatialys.com
Fri Sep 15 09:07:49 PDT 2023
> I agree that there is an untidy legacy. And it's probably not worth
> formalizing the marginal filenames and connection strings. How about
> an RFC and formal syntax only for hierarchical datasets then? It seems
> like this is the direction the industry is growing.
Hiearchical gridded datasets are well covered by the multidimensional
API, which has facilities like
GDALGroupOpenMDArrayFromFullname(hRootGroup,
"/group/subgroup/.../array_name") . What you provide to GDALOpen() when
using the API is the plain filename  (or ZARR:{filename} since it is
sometimes hard for the Zarr driver to recognize datasets otherwise)
> Yes, I think a formal syntax for /vsi filenames would be useful. It's
> almost done already, right?
There's some differences among the /vsi file systems how to provide options
/vsisubfile/<offset>,<filename>
/vsisubfile/<offset>_<size>,<filename>
/vsizip/<filename.zip>/<subpath>
/vsizip/{<container_without_zip_extension>}/<subpath>   (the external {
} are real characters, so an example of this is for example
/vsizip/{my.apk}/file.bin )
/vsicurl?<option1>=<val1>&url=<url>
I've a PR sitting at https://github.com/OSGeo/gdal/pull/8351 to propose
/vsicached?<option1>=<val1>&file=<filename>
http://www.spatialys.com
