[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
    Jonathan Moules
    jonathan-lists at lightpear.com
    Thu Sep 21 05:34:51 PDT 2023
Yeah, I'm afraid the error message is pretty much non-existent:
       File
    "/home/name/Code/DSHub/PoC/Extract-Transform-Load-POC/Metadata/AME/src/info_vector.py",
    line 119, in get_layer_metadata
         tmp_projection = layer.GetSpatialRef()
       File
    "/home/name/anaconda3/envs/AME_env/lib/python3.11/site-packages/osgeo/ogr.py",
    line 1990, in GetSpatialRef
         return _ogr.Layer_GetSpatialRef(self, *args)
    RuntimeError
Suggestions welcome.
On 18/09/2023 12:51, Javier Jimenez Shaw wrote:
> Hi Jonathan
> Which exact RuntimeError are you getting? It can be for several
> reasons (probably an installation or configuration issue).
> Best,
> Javier
> On Mon, 18 Sept 2023 at 11:06, Jonathan Moules
> <jonathan-lists at lightpear.com> wrote:
>     Hi List,
>     I'm trying to get vector layer information via OGR and Python:
>     This works fine for me on Windows with GDAL 3.7.1 on various
>     different
>     types of files (Shapefile, GPKG, GML, KML, GDB).
>     But for my colleague on Ubuntu 22.0.4.3, also on GDAL 3.7.1 (via
>     Conda),
>     they get a Python RuntimeError for all shapefiles (the exact same
>     shapefiles that work fine for me). It works for Geopackages for them.
>     Anyone have any thoughts?
>     Thanks,
>     Jonathan
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230921/04fcf85b/attachment.htm>
