[gdal-dev] GeoTIFF and concurrent block reads
Even Rouault even.rouault at spatialys.com
Thu Sep 21 08:05:34 PDT 2023
> Of course, but I'm asking if it's worth calling ReadBlock on multiple
> threads (if it always takes a lock, it's not, and I should use
> RasterIO instead).
Not on the same dataset object, otherwise you'll get crashes as no lock
is taken
>>> (*) I think these can also be implemented at VSI level by wrapping a
>>> file handle and turning Seek + Read into a PRead (when supported),
>>> even for drivers that don't explicitly support PRead.
>> The multi-threaded optimization also works for VSI file systems not
>> supported PRead(), but doing what you mention above: doing Seek+Read
>> under a lock. This is of course less efficient.
> I meant something slightly different here: if a file supports PRead,
> but a driver doesn't (maybe it's using some external library like
> libtiff, which has _tiffReadProc and _tiffSeekProc), threading could
> still be supported with a hack. The driver could ask the library to
> open the same file multiple times, wrapping the same VSI handle, but
> passing in a seekProc that only keeps track of the current offset. So
> the library could seek and read as it pleases, but GDAL would turn
> those into PRead calls. The backing file handle would never see a
> seek, just PRead.
Ah I see what you mean. Having generic multi-threading isn't possible.
Each driver would have to be modified to be ready to cope with that.
Besides file handles, there are often other state variables at the
GDALDataset/GDALRasterBand level.
> Laurentiu
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230921/d15d4ff5/attachment.htm>
