[gdal-dev] Creation of a new driver from scratch
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Sep 22 04:15:55 PDT 2023
I never used that env bastante before, but it seems to be what you
describe. See that it is enabled also in the tests, as Even says in the
pull 2666
I'm curious. Why do you need to do something different on GDAL compilation?
(I assume it is in a exported header)
On Thu, 21 Sept 2023, 15:56 Abel Pau via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> Hello again!
> I need to know that some shared code is being compiled in GDAL project. I
> can see that GDAL_COMPILATION  (at Preprocessor definition i Visual Studio
> Project) is everywhere.
> It's apropiate to use that variable to know if I am compiling in GDAL or
> not?
> #ifdef GDAL_COMPILATION
> I'm in GDAL
> #else
> I can ignore that code in gdal
> #endif
> I'm not using that in the code, only in some .h
> Thanks!!!
> -----Mensaje original-----
> De: Abel Pau
> Enviado el: dimarts, 5 de setembre de 2023 15:26
> Para: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> Asunto: RE: [gdal-dev] Creation of a new driver from scratch
> Hi again,
> after looking for that in the code, I think that versions depends on
> layer, so -lco is working fine (instead of -dsco, les used).
> So, if there is no inconvenience, I'll use -lco Version=V20, etc...
> Thanks again
> De: Abel Pau <a.pau at creaf.uab.cat>
> Enviado el: dimarts, 5 de setembre de 2023 10:43
> Para: Abel Pau <a.pau at creaf.uab.cat>; Even Rouault <
> Sorry
> there was a mistake. I meant: ogr2ogr src dst -dsco Version=V11 ...
> De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau
> Enviado el: dimarts, 5 de setembre de 2023 10:26
> Asunto: Re: [gdal-dev] Creation of a new driver from scratch
> Hi Everyone,
> Even, after a meeting with the team, we have took in consideration your
> opinion and we have discard the option of writing V1.1 and change to V2.0
> in the middle of writing.
> We have a long tradition with V1.1 and we can't ignore that now but we are
> going to offer both possibilities: read both and write V1.1 and V2.0
> according to user's choice (default 2.0).
> If V1.1 is not enough for its limitations we are going to show a message:
> "MiraMon format limitations." and "Try V2.0 option." and return
> OGRERR_FAILURE;
> Can you confirm that is enough a -f parameter like?
>         For version 1.1:   ogr2ogr src dst - dsco=V11
>         For version 2.0:   ogr2ogr src dst - dsco=V20
>         For last version (to make it simple for possible future
> versions):  ogr2ogr src dst - dsco=last_version
> Thanks a lot for all your kind support.
> De: Even Rouault <even.rouault at spatialys.com> Enviado el: dimecres, 30
> d’agost de 2023 22:57
> Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Abel,
> > I am interested in proportionate 3 ways of proceeding when a used calls
> translation from one format to our format.
> > way 1: force to write V1.1 and stop writing features if the limit is
> reached.
> > way 2: force to write V2.0 (and stop writing features if the limit is
> reached (it will no happen in a near future, I think)).
> > way 3: leave that the program decides if V1.1 is not enough and then it
> changes automatically to V2.0. It does it in the middle of the process,
> when FID or some used internal offset gets the limit.
> Not knowing anything about the ecosystem of the miramon format, but
> ideally I would bend on the side of simplicity if possible, and I would
> just write V2.0 if V1.1 can be considered as a legacy format, that deserves
> perhaps only read-only support (at our times of terabytes+ storage
> capacity, the saving of 4 bytes per feature seems like a anachronic
> concern). But if you really want to use V1.1 when possible and V2.0 only
> when possible, and provided that you implement the writing of the final
> file only at dataset closing as it was my understanding, then you know
> already the max(FID) of features that have been passed to CreateFeature, so
> you could decide automatically the version needed. I would strongly
> discourage starting writing a V1.1 file and then switching to V2.0 in the
> middle of the writing. That sounds like a serious complication.
> > So, my questions:
> > 1.- Which ogr2ogr parameter is the best for doing that?
> >       -f? specificating "MiraMon V1.1" or "MiraMonV2.0" or "MiraMon"
> (automatic way).
> If you really need to implement the 2 formats, a dataset creation option
> in a single driver would probably be better.
> >        Or there is another way I haven't seen (I've read all options
> > in https://gdal.org/programs/ogr2ogr.html#ogr2ogr)
> > 2.- When using -progress some points appear on screen informing the
> progress. At the end of the progress (or sometimes driver requires) there
> is a gap of time that driver is writing some pendant information.
> -progress works by counting the number of features in the source layer,
> and computing the progress percentage at each call to CreateFeature()
> > There is any way to inform the user what the process is doing?
> Not really. You could possibly implement it using CPLDebug() statements if
> you want to monitor the progress in debug mode (the GeoPackage driver
> implemets something similar during spatial index writing, which can be a
> long operation), but there's nothing dedicated in the OGR API or ogr2ogr to
> monitor the progress of long operations occuring during dataset closing, as
> most drivers don't need that.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230922/f33b2d4b/attachment-0001.htm>
