[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Fri Sep 22 07:43:16 PDT 2023
Tested against the following data types (OGR and GDAL):
GeoJSON, KML, KMZ, Shapefile, ECW, IMG, TIF, GML, ASC, Geopackage, NetCDF.
Only the shapefile fails.
On 21/09/2023 13:34, Jonathan Moules wrote:
> Yeah, I'm afraid the error message is pretty much non-existent:
>     Traceback (most recent call last):
>       File
>     "/home/name/Code/DSHub/PoC/Extract-Transform-Load-POC/Metadata/AME/src/info_vector.py",
>     line 119, in get_layer_metadata
>         tmp_projection = layer.GetSpatialRef()
>       File
>     "/home/name/anaconda3/envs/AME_env/lib/python3.11/site-packages/osgeo/ogr.py",
>     line 1990, in GetSpatialRef
>         return _ogr.Layer_GetSpatialRef(self, *args)
>     RuntimeError
> Suggestions welcome.
> On 18/09/2023 12:51, Javier Jimenez Shaw wrote:
>> Hi Jonathan
>> Which exact RuntimeError are you getting? It can be for several
>> reasons (probably an installation or configuration issue).
>> Best,
>> Javier
>> On Mon, 18 Sept 2023 at 11:06, Jonathan Moules
>> <jonathan-lists at lightpear.com> wrote:
>>     Hi List,
>>     I'm trying to get vector layer information via OGR and Python:
>>     This works fine for me on Windows with GDAL 3.7.1 on various
>>     different
>>     types of files (Shapefile, GPKG, GML, KML, GDB).
>>     But for my colleague on Ubuntu 22.0.4.3, also on GDAL 3.7.1 (via
>>     Conda),
>>     they get a Python RuntimeError for all shapefiles (the exact same
>>     shapefiles that work fine for me). It works for Geopackages for them.
>>     Anyone have any thoughts?
>>     Thanks,
>>     Jonathan
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230922/e3537071/attachment.htm>
