[gdal-dev] Using ogr2ogr with limited memory
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Sep 28 01:35:38 PDT 2023
Do you mean that your conversions fail because ogr2ogr does not get enough memory, or do you want to tell ogr2ogr to use max xxx MB of memory even there is much more available?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Scott via gdal-dev
Lähetetty: keskiviikko 27. syyskuuta 2023 6.16
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Using ogr2ogr with limited memory
Any tips for using ogr2ogr to use only a specified amount of RAM? I'm not having any luck.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
