[gdal-dev] Using ogr2ogr with limited memory
Scott public at postholer.com
Thu Sep 28 10:17:45 PDT 2023
USA.fgb is 36 GB. I've renamed it from its original source which can be
found here:
https://beta.source.coop/vida/google-microsoft-open-buildings
ogr2ogr -sql "select area_in_meters from bfp_USA" -nln footprints
footprints.fgb ~/Downloads/USA.fgb
GDAL 3.7.1
OS Debian Buster
Output from ogrinfo -ro -al USA.fgb
Layer name: bfp_USA
Geometry: Unknown (any)
Feature Count: 145459485
Extent: (-160.221701, 17.677691) - (-64.583428, 71.360579)
Layer SRS WKT:
GEOGCRS["WGS 84",
     DATUM["World Geodetic System 1984",
         ELLIPSOID["WGS 84",6378137,298.257223563,
             LENGTHUNIT["metre",1]]],
     PRIMEM["Greenwich",0,
         ANGLEUNIT["degree",0.0174532925199433]],
     CS[ellipsoidal,2],
         AXIS["geodetic latitude (Lat)",north,
             ORDER[1],
         AXIS["geodetic longitude (Lon)",east,
             ORDER[2],
     USAGE[
         SCOPE["unknown"],
         AREA["World"],
         BBOX[-90,-180,90,180]],
     ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
boundary_id: Integer64 (0.0)
bf_source: String (0.0)
confidence: Real (0.0)
area_in_meters: Real (0.0)
OGRFeature(bfp_USA):0
   boundary_id (Integer64) = 116
   bf_source (String) = google
   confidence (Real) = 0.906
   area_in_meters (Real) = 187.4652
   POLYGON ((-64.6399621676723 17.7225504518464,-64.6400377660957
17.722583049763,-64.6400238635835 17.7226126625647,-64.6400901719124
17.7226412545727,-64.640104074415
  17.722611641767,-64.6401239848718 17.7226202271066,-64.6401528522526
17.7225587385527,-64.6400955687758 17.7225340380511,-64.6401051288881
17.7225136746756,-64.640040
1136221 17.7224856402151,-64.640030553504
17.7225060035881,-64.6399910351014 17.7224889633119,-64.6399621676723
17.7225504518464))
OGRFeature(bfp_USA):1
   bf_source (String) = microsoft
   area_in_meters (Real) = 51.0777955237376
   POLYGON ((-64.6398677811851 17.7219759840792,-64.6397939789141
17.7219853127982,-64.6398020235506 17.7220430591893,-64.6398758258215
17.7220337304732,-64.63986778118
51 17.7219759840792))
OGRFeature(bfp_USA):2
   confidence (Real) = 0.8323
   area_in_meters (Real) = 178.5448
   POLYGON ((-64.6397672401299 17.7220665249078,-64.6397654280552
17.722041016034,-64.6395789582891 17.7220531822569,-64.6395832735872
17.7221139302758,-64.639696737462
3 17.7221065273415,-64.639698399651 17.7221299263498,-64.6398064310524
17.7221228777942,-64.6398022655579 17.7220642396531,-64.6397672401299
17.7220665249078))
On 9/28/23 10:03, Even Rouault wrote:
> Le 28/09/2023 à 18:47, Scott via gdal-dev a écrit :
>> I should have been more specific.
>> One particular machine has 8GB of memory. When I try to do the most
>> simple ogr2ogr command on large files, the host runs out of memory
>> (vmstat shows this) and ogr2ogr terminates with 'Killed', nothing more.
>> The data formats I have experienced this with are .fgb, .parquet and
>> .gpkg. The data files are 10's of GB.
> As input ? as output? Which operating system ? Which GDAL version ? The
> output of "ogrinfo -al -so the_input" might also be helpful. An exact
> ogr2ogr command line invocation that triggers the issue would certainly
> be useful.  In general, most GDAL drivers and ogr2ogr itself operate in
> streaming mode with low RAM requirements, but there might be exceptions
> (some configurations of GeoJSON file may require full ingestion on
> reading for example).  I'm also aware of issues with RAM fragmentation
> due to how some memory allocators work, but they seem to be restricted
> to multithreaded uses
> (https://gdal.org/user/multithreading.html#ram-fragmentation-and-multi-threading), which current ogr2ogr shouldn't trigger
> Even
>> Thanks for the responses!
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
