[gdal-dev] About installing EXPAT
Abel Pau a.pau at creaf.uab.cat
Fri Sep 29 21:54:54 PDT 2023
Stefan,
I finally did it well and now it works!!!!
Thanks a lot for your help!!
De: Uhrig, Stefan <stefan.uhrig at sap.com>
Enviado el: divendres, 29 de setembre de 2023 17:36
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal dev <gdal-dev at lists.osgeo.org>
Asunto: RE: [gdal-dev] About installing EXPAT
Hi Abel,
Hmm, I did not build with SWIG and Python. Your build log also looks very different from mine. I wonder why you have all those separate projects. For me, it was just one project with 1351 tasks.
Let me share the output of my project configuration. Maybe it will help:
1> [CMake] -- The C compiler identification is MSVC 19.37.32824.0
1> [CMake] -- The CXX compiler identification is MSVC 19.37.32824.0
1> [CMake] -- Detecting C compiler ABI info
1> [CMake] -- Detecting C compiler ABI info - done
1> [CMake] -- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Enterprise/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
1> [CMake] -- Detecting C compile features
1> [CMake] -- Detecting C compile features - done
1> [CMake] -- Detecting CXX compiler ABI info
1> [CMake] -- Detecting CXX compiler ABI info - done
1> [CMake] -- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Enterprise/VC/Tools/MSVC/14.37.32822/bin/Hostx64/x64/cl.exe - skipped
1> [CMake] -- Detecting CXX compile features
1> [CMake] -- Detecting CXX compile features - done
1> [CMake] -- Performing Test test_AVX
1> [CMake] -- Performing Test test_AVX - Success
1> [CMake] -- Performing Test test_AVX2
1> [CMake] -- Performing Test test_AVX2 - Success
1> [CMake] -- Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
1>  [CMake] -- Could NOT find Python (missing: Python_NumPy_INCLUDE_DIRS NumPy) (found suitable version "3.11.1", minimum required is "3.6")
[deleted ...]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230930/4f72a869/attachment.htm>
