[gdal-dev] HDF5 and identified fields / primary dimension
Even Rouault even.rouault at spatialys.com
Mon Apr 1 16:46:48 PDT 2024
Michael,
> Warning 1: The dataset has several variables that could be identified
> as vector fields, but not all share the same primary dimension.
> Consequently they will be ignored.
Yes, the driver is super conservative/picky when trying to recognize a
netCDF file as a vector layer, and its heuristics will return in error
if there is any ambiguity.
> I've seen similar cases in other files. I presume the driver could be
> updated to 1) choose the primary dimension and read the values while
> ignore others 2) user-specify the dimension to include, or 3)
> user-specify the fields to exclude
I guess option 2 could be reasonable as an open option
For that particular file, I see that the "feature_id" variable
(corresponding to the "feature_id" dimension) has a cf_role =
"timeseries_id" attribute, and that the global metadata has a
featureType = "timeSeries" attribute. So given
https://cfconventions.org/Data/cf-conventions/cf-conventions-1.11/cf-conventions.html#coordinates-metadata
, this seems to be relatively standardized, and in that case the
heuristics could be improve to recognize that the main dimension is
feature_id (probably with a test that the size of the time dimension is
1).  As far as I can see/remember, the vector layer support in netCDF
was originally developed for the featureType=point and profile use cases
, so some tuning for timeseries isn't unexpected
Or maybe if detecting that in the set of dimensions there is only one
with > 1 sample and others ones are at 1, consider only the one with > 1
sample
Even
http://www.spatialys.com
