[gdal-dev] LAUNDER option for geopackages
Robert Hewlett rob.hewy at gmail.com
Wed Apr 3 07:51:10 PDT 2024
Is there a LAUNDER for geopackages?
I ask this because at the following site:
https://www.geopackage.org/guidance/getting-started.html
Gives this specific guidance:
Note: *For maximum interoperability,* start your database identifiers
(table names, column names, etc.) with a lowercase character and only
use *lowercase
characters*, numbers 0-9, and underscores (_).
Which then turned into a *constraint* in GeoNode (I could not upload a
certain geopackage from the township of langley) where I eventually
discovered in the celery logs this error:
ERROR/ForkPoolWorker-958] {'validation_code': 'RQ1',
'validation_description': 'Layer names must start with a letter, and
*valid characters are lowercase a-z*, numbers or underscores.', 'level':
'error', 'locations': ['Error layer: Parcel_Attributes']}
I would love LAUNDER to be a more global option.
Upper for: Oracle and Shapefiles.
Lower for: Postgresql, Mysql, geopackages
Just wondering,
Rob
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240403/c31cfbb6/attachment.htm>
