[gdal-dev] LAUNDER option for geopackages
Even Rouault even.rouault at spatialys.com
Wed Apr 3 13:59:52 PDT 2024
I've given this a crack at https://github.com/OSGeo/gdal/pull/9609
The newly introduced LAUNDER option for GeoPackage is indeed quite
"extreme" compared to the existing ones, hence I've defaulted it to NO.
I've also added a LAUNDER_ASCII option to PG/PGDump to do something
similar to GeoPackage LAUNDER.
Even
Le 03/04/2024 à 17:50, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> The GeoPackage standard recommends some laundering to be done by the
> clients:
> Implementers should be aware of the fact that SQLite table names are
> not case
> sensitive and that table names in sqlite_master and gpkg_extensions
> may not have
> the same case. When searching for table name references, it is
> recommended to
> transform table names to lower case with the lower() function. See the
> Abstract
> Test Suite for an example.
> If GeoNode does not have any other reason for its requirement than
> what you have pointed out, then maybe it is too strict.
> Having launder in GPKG driver feels still reasonable. SQLite driver
> has it already https://gdal.org/drivers/vector/sqlite.html.
> “LAUNDER=[YES/NO]: Defaults to YES. Controls whether layer and field
> names will be laundered for easier use in SQLite. Laundered names will
> be converted to lower case and some special characters(' - #) will be
> changed to underscores.”
> It is either not documented or not implemented, but laundering
> identifiers to work without "quotas" would also require removing
> numbers from the beginning of the name. And at least % should be added
> to the list of special characters. But total laundering requires quite
> a lot https://www.sqlite.org/draft/tokenreq.html.
> Laundering characters like äöå for GeoNode feels too much. Who would
> say into what characters to launder?
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Robert Hewlett via gdal-dev
> *Lähetetty:* keskiviikko 3. huhtikuuta 2024 17.51
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] LAUNDER option for geopackages
> Hi,
> Is there a LAUNDER for geopackages?
> I ask this because at the following site:
> https://www.geopackage.org/guidance/getting-started.html
> Gives this specific guidance:
> Note: *For maximum interoperability,* start your database identifiers
> (table names, column names, etc.) with a lowercase character and only
> use *lowercase characters*, numbers 0-9, and underscores (_).
> Which then turned into a *constraint* in GeoNode (I could not upload a
> certain geopackage from the township of langley) where I eventually
> discovered in the celery logs this error:
> ERROR/ForkPoolWorker-958] {'validation_code': 'RQ1',
> 'validation_description': 'Layer names must start with a letter, and
> *valid char
> acters are lowercase a-z*, numbers or underscores.', 'level': 'error',
> 'locations': ['Error layer: Parcel_Attributes']}
> I would love LAUNDER to be a more global option.
> Upper for: Oracle and Shapefiles.
> Lower for: Postgresql, Mysql, geopackages
> Just wondering,
> Rob
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240403/4769d49b/attachment.htm>
