[gdal-dev] Unsupported HTTPAUTH value 'BEARER', ignored
Even Rouault even.rouault at spatialys.com
Thu Apr 4 07:14:59 PDT 2024
GDAL_HTTP_AUTH=BEARER support has been added in master / GDAL 3.9dev
only (I've just fixed an erroneous statement about it being in 3.8)
In earlier versions, you can try setting
GDAL_HTTP_HEADERS="Authentication: Bearer {your_token_here}"
Even
Le 04/04/2024 à 15:40, Michael Otto via gdal-dev a écrit :
> Hello,
> I am trying to pass an authentication for requests to WFS services. As
> a test, I have activated the logging of curl and have the errors
> output to a log file.
> With HTTP-Basic authentication it seems to work with the following
> parameters (no errors are logged):
> 'Auth' is my ArrayList to use in java processbuilder.
> Auth:[[--config, GDAL_HTTP_AUTH, BASIC, --config, GDAL_HTTP_USERPWD,
> username:password]]
> But try this for Bearer :
> Auth:[[--config, GDAL_HTTP_AUTH, BEARER, --config, GDAL_HTTP_BEARER,
> token]]
> I get the following error in the error log:
> Warning 1: Unsupported HTTPAUTH value 'BEARER', ignored.
> What am I doing wrong and what can I do so that Bearer authentication
> is also accepted?
> Can I use curl paramters directly instead?
> Michael
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240404/a4da2977/attachment.htm>
