[gdal-dev] How do I add a projection to proj 8?
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Sat Apr 13 12:20:00 PDT 2024
On 4/13/2024 1:26 PM, Javier Jimenez Shaw wrote:
> On Sat, 13 Apr 2024 at 17:35, Stephen Woodbridge via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
>     Thanks, this is NOT the standard Web Mercator projection. I am
>     aware of EPSG:90013 and EPSG:3857. This projection is used with
>     HYCOM data that I have extracted into geotif files so that I can
>     accurately project that onto EPSG:3857. It took some fiddling with
>     the values to get to overlay visually correctly. HYCOM data is
>     weird in that it uses two different projections based on if the
>     data is above or below some latitude.
> I found something like that in the Internet. But I was not sure it was
> the right one https://polar.ncep.noaa.gov/global/about/ It didn't
> specify the projections, just a short description as Arctic bi-polar
> patch north of 47N, and Mercator south of it.
Yes this what is happening with the HYCOM data. The projection
definition in PROJ4 worked quite well for my case of web mapping in
mapserver.
> I do not know if you can specify a projection "in parts" respect to
> parallel 47. Maybe in WKT2.
> Where did you found those parameters for the datum and projection?
> They are quite strange.
> For the ellipsoid there are a few already with a similar radius:
> SELECT * from ellipsoid where semi_major_axis BETWEEN 6371000 and 6371010
> EPSG 	7035 	Sphere
> 	PROJ 	EARTH 	6371000.0 	EPSG 	9001
> 	6371000.0 	1
> EPSG 	7048 	GRS 1980 Authalic Sphere
> 	PROJ 	EARTH 	6371007.0 	EPSG 	9001
> 	6371007.0 	0
> ESRI 	107047 	Sphere_GRS_1980_Mean_Radius 	Sphere with mean radius
> based on GRS80 	PROJ 	EARTH 	6371008.7714 	EPSG 	9001 	0.0
> 	0
> And datums
> SELECT * from geodetic_datum where ellipsoid_code in (7035, 7048, 107047)
> EPSG 	6035 	Not specified (based on Authalic Sphere)
> 	EPSG 	7035 	EPSG 	8901
> 	1
> EPSG 	6047 	Not specified (based on GRS 1980 Authalic Sphere)
> 	EPSG 	7048 	EPSG 	8901
> 	1
> ESRI 	106047 	D_Sphere_GRS_1980_Mean_Radius 	GRS 1980 Mean Radius
> Sphere 	ESRI 	107047 	EPSG 	8901
> 	0
> and geographic crs
> SELECT * from geodetic_crs where datum_code in (6035, 6047, 106047)
> EPSG 	4035 	Unknown datum based upon the Authalic Sphere
> 	geographic 2D 	EPSG 	6402 	EPSG 	6035
> 	1
> EPSG 	4047 	Unspecified datum based upon the GRS 1980 Authalic Sphere
> 	geographic 2D 	EPSG 	6422 	EPSG 	6047
> 	1
> ESRI 	104047 	GCS_Sphere_GRS_1980_Mean_Radius
> 	geographic 2D 	EPSG 	6422 	ESRI 	106047
> 	0
> See that EPSG ones are deprecated. (surprisingly the ellipsoid
> EPSG:7048 is not deprecated, but the datum that uses it is deprecated).
>     On 4/13/2024 4:19 AM, Javier Jimenez Shaw via gdal-dev wrote:
>>     If what you need is really EPSG:3857, yes, use it.
>>     However I have seen strange parameters on your projection. The
>>     radius of the sphere is the "average" 3671 km, and you set a
>>     false easting and northing of just 4.4 km. Is that trying to
>>     correct the radius of the sphere? I do not know why you need that.
>>     Bas, are they really equivalent?
>>     In proj you can convert to WKT1 (see that I added +type=crs):
>>     projinfo "+proj=merc +a=6371001 +b=6371001 +lat_ts=0.0 +lon_0=0.0
>>     +x_0=-4448 +y_0=-4448 +k=1.0 +units=m +over +nadgrids=@null
>>     +no_defs  +type=crs" -o wkt1_gdal
>     Ok I get this adding by +type=crs but how do I add it to the proj
>     database so I can access it referencing it by something like
>     EPSG:90014?
> Is a WKT string enough?
> PROJCS["unknown",
>     GEOGCS["unknown",
>         DATUM["unknown using nadgrids=@null",
>             SPHEROID["unknown",6371001,0]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9122"]]],
>     PROJECTION["Mercator_1SP"],
>     PARAMETER["central_meridian",0],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",-4448],
>     PARAMETER["false_northing",-4448],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AXIS["Easting",EAST],
>     AXIS["Northing",NORTH],
>     EXTENSION["PROJ4","+proj=merc +a=6371001 +b=6371001 +lat_ts=0.0
> +lon_0=0.0 +x_0=-4448 +y_0=-4448 +k=1.0 +units=m +over +nadgrids=@null
> +no_defs"]]
> (generated with the projinfo line from prev email) Using a geographic
> CRS as described above will make it nicer, and probably more compatible.
> You can use it in QGIS for instance. I am not sure how does it behave
> in a GeoTIFF, as it has some special tags. You can try to generate the
> geotiff with gdal with that WKT, and see that happens.
> About adding to proj.db as EPSG:900914, I am not sure of all the
> steps. But I would say that you have to create a datum and a
> geographic crs (or use one of the above), in addition to the
> projection (conversion, parameters, etc) and the projected crs. And
> then "compile" the database.
> Is it worth it?
> In case you modify proj.db, instead of using EPSG, you can create your
> own authority, or use "PROJ" authority. It will be cleaner.
Ok, thanks, I think I can work with this information. I appreciate the
help.
I'm also considering rewriting the extraction utility to totally avoid
using this projection. This might be the better choice long term.
Thanks,
   -Steve
>     Thanks,
>       -Steve
>>     On Sat, 13 Apr 2024 at 06:17, Sebastiaan Couwenberg via gdal-dev
>>         On 4/12/24 11:24 PM, Stephen Woodbridge via gdal-dev wrote:
>>         > and was able to access it in gdal, mapserver, postgis, etc
>>         with
>>         > "EPSG:900914"
>>         I used to do that too, but switched to EPSG:3857 its
>>         non-deprecated
>>         equivalent. I would recommend that instead of trying to keep
>>         using a
>>         non-standard projection.
>>         Kind Regards,
>>         Bas
>>           GPG Key ID: 4096R/6750F10AE88D4AF1
>>         Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>>         _______________________________________________
>>         gdal-dev mailing list
>>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>     	Virus-free.www.avast.com
>     <#m_-2289715080308317683_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
This email has been checked for viruses by Avast antivirus software.
www.avast.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240413/26f47e8b/attachment-0001.htm>
