[gdal-dev] gdalwarp with RPCs causing bogus output
Joseph McGlinchy jmcglinchy at hydrosat.com
Wed Apr 17 18:33:00 PDT 2024
Hi Even,
Thank you for this great response. I'll try out some of those things you mention on the CRS of the DEM and correcting for the geoid; I had also been reading that any height values used in this process need to be heights above the ellipsoid.
I had seen good outputs from gdaltransform​, both forward and inverse, and can get back to the corner coordinates, center coordinates, etc. in both lon/lat and sample/line so it could be a subtlety of the DEM + CRS, or the more challenging issue of stable RPCs.
On the topic of stable RPCs, do you happen to know if it is enough to zero out the higher-order terms after the full set of coefficients are fit? Since there are squared terms in the higher-order coefficients, that could definitely be part of the issue, even if it works mathematically.
thanks!
Joe
Sent: Wednesday, April 17, 2024 4:20 PM
To: Joseph McGlinchy <jmcglinchy at hydrosat.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] gdalwarp with RPCs causing bogus output
I haven't done myself that exercice but I know that computing RPC values that are stable enough might be challenging, so perhaps the issue is related to that
A few other remarks:
- your gdalwarp command line refers to  RPC_DEM_SRS and RPC_DEM_MISSING_VALUE but doesn't include a RPC_DEM itself, hence those are likely to be non effective
- you generally don't want to use both RPC_HEIGHT and RPC_DEM.  RPC_HEIGHT is essentially useful when you don't have a DEM available, and thus fallback taking an average elevation
- there's a subtlety regarding DEM. RPC reference for altitudes is WGS84 ellipsoidal height, not orthometric/MSL altitude. But DEM values use orthometric/MSL altitude, hence a geoid correction must be applied. So you'd rather want to use RPC_DEM_SRS=EPSG:4326+5773 for example to use the EGM96 geoid (cf https://github.com/OSGeo/gdal/issues/3298). That said, misusing orthometric altitude vs ellipsoidal height generally accounts for small shifts, not big ones
- you could use gdaltransform with all your -to parameter and input_with_RPCs.tiff to check at least that the forward RPC transformation path works correctly (the one from longitude, latitude -> column, line). And with -i to check the inverse RPC transformer. The inverse RPC transformer can have a hard time converging in montainous areas or for images off-nadir
Even
Le 17/04/2024 à 23:30, Joseph McGlinchy via gdal-dev a écrit :
Hello,
I am attempting to implement georegistration through RPC. I have the following information I've used to calibrate the RPC coefficients, using all terms for numerator and denominator for both sample and line equations.
image grid, stored in tiff format with no geo-information associated with it, so it reflects the imaging orientation
a 'ground' grid, which corresponds to the longitude/latitude coordinates for each pixel determined from a line-of-sight vector and imaging system coordinates where the pseudo-rays intersect the WGS84 geoid
a random sample of up to 4000 image coordinate / object space coordinate pairs (I arrived at this number through trial and error; using all pixels explodes RAM)
elevation extracted at the longitude/latitude coordinates from a DEM, in this case, SRTM, but have also tried using NASADEM
I am able to write out an image to EPSG:4326 by populating the RPC metadata and using the non-georeferenced image data. However, I am struggling to use gdalwarp​ in a reliable way to orthorectify that data, let alone writing it out in a way that 'bakes in' the georegistration with the RPCs whether that is in EPSG:4326 or the local UTM zone. I see strips of the image "ripped out" with odd curves in various places throughout the image.
The only way I've been able to use gdalwarp​ to write the image at all is with the following parameters (any DEM reference is to the SRTM DEM):
gdalwarp --config CPL_DEBUG ON -t_srs EPSG:32610 -rpc -to "RPC_DEM_SRS=+proj=longlat +datum=WGS84 +no_def" -to "RPC_HEIGHT=350" -to "RPC_DEM_MISSING_VALUE=0.001" -to "RPC_FOOTPRINT='POLYGON ((list of polygon coordinates comprising the long/lat grid))'" -to "RPC_MAX_ITERATIONS=101" input_with_RPCs.tiff output.tiff
This is the only configuration i can use to run gdalwarp​ successfully.  removing any single RPC_X tranformer option gives me bogus output. The RPC_HEIGHT value i specify above is not close to the mean or median elevation of the extent of my data; mean is ~195m and median is ~150m.
With the debug turned on, any other set of parameters gives me failed RPC convergence on several points. I am able to reproduce this regularly by specifying RPC_DEM=dem.tif, where dem.tif is the same data I used to extract elevation values when calibrating the RPCs. I am seeing normalized latitude and longitude values with magnitude > 1 (I checked every location in the image, based on the metadata, the range is not outside of [-1,1]), as well as normalized altitude values with magnitude > 1 (there are some, not many, that have magnitude of 1.75).
My workflow can be summarized as:
  1.
load grids (image data, longitude, latitude)
  2.
randomly sample up to 4000 points in image coordinates, object coordinates
assign z-value from SRTM DEM
evaluate if any of the points are in NODATA areas of SRTM (image is coastal, so there are NODATA areas for SRTM here), if so, remove those and generate more points
  3.
normalize coordinates of grids to be in [-1,1], recording offsets and scale
  4.
 calibrate RPC coefficients using all terms
  5.
write out GeoTIFF with image grid for pixels, along with RPC required metadata fields and CRS EPSG:4326
System information (please let me know if more is needed)
OS: Ubuntu 20.04 LTS (GNU/Linux 5.10.16.3-microsoft-standard-WSL2 x86_64) (Windows Subsystem for Linux)
GDAL 3.6.0 (python)
Thank you in advance for any insight into this process! I am happy to package up any of the data I am using, as well. I have placed the initial data from the end of Step 5 described above, along with some additional files, a sample gdalwarp call, and a file-list.txt, at https://drive.google.com/drive/folders/1BfevhKQa4ZHi_OQfiX_rUk2sqeoNVhyM?usp=sharing
If more is needed for anyone interested in having a look, please let me know and I'll upload.
Cheers,
Joe
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240418/169348aa/attachment-0001.htm>
