[gdal-dev] gdalwarp with RPCs causing bogus output
Joseph McGlinchy jmcglinchy at hydrosat.com
Thu Apr 18 11:02:12 PDT 2024
Hi Daniel,
Thank you.  I tried your commands exactly with gdal 3.8.3 and am seeing the odd type of output I was describing in the northeastern most reaches of the images. Would you be willing to verify if you see that or not?
Here is the result of the debug messaging. I think a screenshot which shows what I see results in the message being over the size limit.
GDAL: GDALOpen(../manyPts4000_SRTM_test_NptRPC.tiff, this=0x5584b5c21370) succeeds as GTiff.
GDAL: GDALOpen(output_gdal38.tiff, this=0x5584b5c4c950) succeeds as GTiff.
GDALWARP: Defining SKIP_NOSOURCE=YES
Processing ../manyPts4000_SRTM_test_NptRPC.tiff [1/1] : 0WARP: Copying metadata from first source to destination dataset
WARP: Set SOURCE_EXTRA=5 warping options due to RPC warping
WARP: Set SAMPLE_STEPS=ALL warping options due to RPC DEM warping
GDAL: GDALOpen(srtm_12_05.tif, this=0x5584b5c522a0) succeeds as GTiff.
RPC: Short-circuiting coordinate transformation from DEM SRS to WGS 84 due to apparent nop
GDAL: GDAL_CACHEMAX = 1504 MB
GTiff: ScanDirectories()
GDAL: GDALDefaultOverviews::OverviewScan()
Using internal nodata values (e.g. 0) for image ../manyPts4000_SRTM_test_NptRPC.tiff.
WARP: band=0 dstNoData=0.000000
RPC: Failed Iterations 101: Got: -121.6743548438707,37.81305392714289  Offset=0.200509,-7.35862
WARP: At least one point failed after direct transform
RPC: Failed Iterations 101: Got: -121.6756957607436,37.81515846637773  Offset=-0.0317686,-12.1573
RPC: Failed Iterations 101: Got: -121.6759688314497,37.81397923057818  Offset=-0.0782949,-21.942
RPC: Failed Iterations 101: Got: -121.6760567085541,37.81393132082147  Offset=-0.0200723,-13.2144
RPC: Failed Iterations 101: Got: -121.6758750148136,37.8150256294207  Offset=0.0121725,-8.26664
RPC: Failed Iterations 101: Got: -121.6758055299304,37.81513471897441  Offset=0.0111142,-9.29081
RPC: Failed Iterations 101: Got: -121.6757471773221,37.81517816256341  Offset=0.00786933,-9.66179
RPC: Failed Iterations 101: Got: -121.6757610763044,37.81516845364766  Offset=0.00852169,-9.58453
GDAL: GDALSuggestedWarpOutput(): 1 out of 3249 points failed to transform.
GDAL: GDALWarpKernel()::GWKNearestShort() Src=0,0,2383x2800 Dst=0,0,2411x3318
...10...20...30...40...50GDAL: GDALWarpKernel()::GWKNearestShort() Src=1710,0,1460x1401 Dst=2411,0,1205x1659
...60GDAL: GDALWarpKernel()::GWKNearestShort() Src=2833,0,1263x2458 Dst=3616,0,1206x829
...GDAL: GDALWarpKernel()::GWKNearestShort() Src=2995,148,1101x1054 Dst=3616,829,1206x830
70..GDAL: GDALWarpKernel()::GWKNearestShort() Src=2036,993,2060x1807 Dst=2411,1659,2411x1659
.80...90...100 - done.
GDAL: GDALClose(srtm_12_05.tif, this=0x5584b5c522a0)
GDAL: Flushing dirty blocks: 0...10...20...30...40...50...60...70...80...90...100 - done.
GDAL: GDALClose(output_gdal38.tiff, this=0x5584b5c4c950)
GDAL: GDALClose(../manyPts4000_SRTM_test_NptRPC.tiff, this=0x5584b5c21370)
From: Daniel Evans <daniel.fred.evans at gmail.com>
Sent: Thursday, April 18, 2024 9:03 AM
To: Joseph McGlinchy <jmcglinchy at hydrosat.com>
Cc: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] gdalwarp with RPCs causing bogus output
Hi Joe,
My minimal change is just to add the missing "RPC_DEM=srtm_12_05.tif" and remove the "RPC_HEIGHT=350". RPC_HEIGHT appears to override the use of any supplied DEM, and the docs at least hint that this is the expected behaviour.
gdalwarp --config CPL_DEBUG ON \
    -t_srs EPSG:32610 \
    -rpc \
    -to "RPC_DEM_SRS=+proj=longlat +datum=WGS84 +no_def" \
    -to "RPC_DEM_MISSING_VALUE=0.001" \
    -to "RPC_FOOTPRINT='POLYGON ((-123.12941327726458 38.01872167010621, -121.67068342817124 37.82615456858018, -121.87575337280391 37.11164114368971, -123.32135086275996 37.30124603928108, -123.12941327726458 38.01872167010621))'" \
    -to "RPC_MAX_ITERATIONS=101" \
    -to "RPC_DEM=srtm_12_05.tif" \
    manyPts4000_SRTM_test_NptRPC.tiff \
    output.tiff
Changing to "RPC_DEM_SRS=EPSG:4326+5773" as Even suggested gives a noticeable change around the DEM locations of dams and lakes with the updated CRS, e.g. west and north of Livermore CA. Whether that's an improvement, or an undesired change due to the DEM being treated differently between generating the RPCs and using them, I'm not sure!
Daniel
On Thu, 18 Apr 2024 at 15:39, Joseph McGlinchy <jmcglinchy at hydrosat.com<mailto:jmcglinchy at hydrosat.com>> wrote:
Hi Daniel,
Thanks for trying with the data! I appreciate that. The gdal command I provided in the sample-gdal-call.txt file is the only one I could get to have "good" looking results. What command did you use to include the DEM?
If there has been a fix between 3.6 and 3.8.3 that helps with this, then I'm happy to try it. I'll give that a look too.
thanks!
Joe
From: Daniel Evans <daniel.fred.evans at gmail.com<mailto:daniel.fred.evans at gmail.com>>
Sent: Thursday, April 18, 2024 5:44 AM
To: Joseph McGlinchy <jmcglinchy at hydrosat.com<mailto:jmcglinchy at hydrosat.com>>
Cc: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Hi Joe,
Trying your commands with GDAL 3.8.3, the results don't seem to be as bad as what you're reporting - I don't see big strips missing. Adding in the DEM file as Even mentioned, it seems to be doing what I'd expect (the correction isn't "right" because of the georeferencing offset, but it's doing what it's told using the underlying DEM).
Any possibility of trying a newer GDAL version in case there has been a fix since 3.6.0?
Cheers,
Daniel
On Thu, 18 Apr 2024 at 02:35, Joseph McGlinchy via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Hi Even,
Thank you for this great response. I'll try out some of those things you mention on the CRS of the DEM and correcting for the geoid; I had also been reading that any height values used in this process need to be heights above the ellipsoid.
I had seen good outputs from gdaltransform​, both forward and inverse, and can get back to the corner coordinates, center coordinates, etc. in both lon/lat and sample/line so it could be a subtlety of the DEM + CRS, or the more challenging issue of stable RPCs.
On the topic of stable RPCs, do you happen to know if it is enough to zero out the higher-order terms after the full set of coefficients are fit? Since there are squared terms in the higher-order coefficients, that could definitely be part of the issue, even if it works mathematically.
thanks!
Joe
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sent: Wednesday, April 17, 2024 4:20 PM
To: Joseph McGlinchy <jmcglinchy at hydrosat.com<mailto:jmcglinchy at hydrosat.com>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
I haven't done myself that exercice but I know that computing RPC values that are stable enough might be challenging, so perhaps the issue is related to that
A few other remarks:
- your gdalwarp command line refers to  RPC_DEM_SRS and RPC_DEM_MISSING_VALUE but doesn't include a RPC_DEM itself, hence those are likely to be non effective
- you generally don't want to use both RPC_HEIGHT and RPC_DEM.  RPC_HEIGHT is essentially useful when you don't have a DEM available, and thus fallback taking an average elevation
- there's a subtlety regarding DEM. RPC reference for altitudes is WGS84 ellipsoidal height, not orthometric/MSL altitude. But DEM values use orthometric/MSL altitude, hence a geoid correction must be applied. So you'd rather want to use RPC_DEM_SRS=EPSG:4326+5773 for example to use the EGM96 geoid (cf https://github.com/OSGeo/gdal/issues/3298). That said, misusing orthometric altitude vs ellipsoidal height generally accounts for small shifts, not big ones
- you could use gdaltransform with all your -to parameter and input_with_RPCs.tiff to check at least that the forward RPC transformation path works correctly (the one from longitude, latitude -> column, line). And with -i to check the inverse RPC transformer. The inverse RPC transformer can have a hard time converging in montainous areas or for images off-nadir
Even
Le 17/04/2024 à 23:30, Joseph McGlinchy via gdal-dev a écrit :
Hello,
I am attempting to implement georegistration through RPC. I have the following information I've used to calibrate the RPC coefficients, using all terms for numerator and denominator for both sample and line equations.
image grid, stored in tiff format with no geo-information associated with it, so it reflects the imaging orientation
a 'ground' grid, which corresponds to the longitude/latitude coordinates for each pixel determined from a line-of-sight vector and imaging system coordinates where the pseudo-rays intersect the WGS84 geoid
a random sample of up to 4000 image coordinate / object space coordinate pairs (I arrived at this number through trial and error; using all pixels explodes RAM)
elevation extracted at the longitude/latitude coordinates from a DEM, in this case, SRTM, but have also tried using NASADEM
I am able to write out an image to EPSG:4326 by populating the RPC metadata and using the non-georeferenced image data. However, I am struggling to use gdalwarp​ in a reliable way to orthorectify that data, let alone writing it out in a way that 'bakes in' the georegistration with the RPCs whether that is in EPSG:4326 or the local UTM zone. I see strips of the image "ripped out" with odd curves in various places throughout the image.
The only way I've been able to use gdalwarp​ to write the image at all is with the following parameters (any DEM reference is to the SRTM DEM):
gdalwarp --config CPL_DEBUG ON -t_srs EPSG:32610 -rpc -to "RPC_DEM_SRS=+proj=longlat +datum=WGS84 +no_def" -to "RPC_HEIGHT=350" -to "RPC_DEM_MISSING_VALUE=0.001" -to "RPC_FOOTPRINT='POLYGON ((list of polygon coordinates comprising the long/lat grid))'" -to "RPC_MAX_ITERATIONS=101" input_with_RPCs.tiff output.tiff
This is the only configuration i can use to run gdalwarp​ successfully.  removing any single RPC_X tranformer option gives me bogus output. The RPC_HEIGHT value i specify above is not close to the mean or median elevation of the extent of my data; mean is ~195m and median is ~150m.
With the debug turned on, any other set of parameters gives me failed RPC convergence on several points. I am able to reproduce this regularly by specifying RPC_DEM=dem.tif, where dem.tif is the same data I used to extract elevation values when calibrating the RPCs. I am seeing normalized latitude and longitude values with magnitude > 1 (I checked every location in the image, based on the metadata, the range is not outside of [-1,1]), as well as normalized altitude values with magnitude > 1 (there are some, not many, that have magnitude of 1.75).
My workflow can be summarized as:
  1.
load grids (image data, longitude, latitude)
  2.
randomly sample up to 4000 points in image coordinates, object coordinates
assign z-value from SRTM DEM
evaluate if any of the points are in NODATA areas of SRTM (image is coastal, so there are NODATA areas for SRTM here), if so, remove those and generate more points
  3.
normalize coordinates of grids to be in [-1,1], recording offsets and scale
  4.
 calibrate RPC coefficients using all terms
  5.
write out GeoTIFF with image grid for pixels, along with RPC required metadata fields and CRS EPSG:4326
System information (please let me know if more is needed)
OS: Ubuntu 20.04 LTS (GNU/Linux 5.10.16.3-microsoft-standard-WSL2 x86_64) (Windows Subsystem for Linux)
GDAL 3.6.0 (python)
Thank you in advance for any insight into this process! I am happy to package up any of the data I am using, as well. I have placed the initial data from the end of Step 5 described above, along with some additional files, a sample gdalwarp call, and a file-list.txt, at https://drive.google.com/drive/folders/1BfevhKQa4ZHi_OQfiX_rUk2sqeoNVhyM?usp=sharing
If more is needed for anyone interested in having a look, please let me know and I'll upload.
Cheers,
Joe
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240418/0f368c55/attachment-0001.htm>
