[gdal-dev] Issue with 3D GeoJSON to 3D DXF Conversion
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 22 04:18:18 PDT 2024
By reading the documentation https://gdal.org/drivers/vector/dxf.html#dxf-writer what you see is expected. --config DXF_WRITE_HATCH FALSE is writing polylines and polylines have vertices with different Z coordinates. --config DXF_WRITE_HATCH TRUE writes polygons. The polygons have same elevation value at each vertex, and that is also documented:
“You may need to do this [to use DXF_WRITE_HATCH FALSE] if your geometries do not have a constant elevation, as the DXF HATCH entity cannot represent such geometries.”
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Shahrukh Mirza Nawandish via gdal-dev
Lähetetty: maanantai 22. huhtikuuta 2024 13.26
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Issue with 3D GeoJSON to 3D DXF Conversion
Dear GDAL Team,
I hope this email finds you well. I'm encountering an issue converting 3D GeoJSON polygons to DXF format using ogr2ogr. During conversion, the elevation data becomes uniform for all points within the polygon. Additionally, when using "DXF_WRITE_HATCH," the geometry becomes a polyline instead of a polygon.
Attached are the GeoJSON data and conversion code for your reference. Could you please assist in resolving this discrepancy?
ogr2ogr -f "DXF" output.dxf input.geojson -t_srs EPSG:32737 --config DXF_WRITE_HATCH FALSE
Thank you for your attention to this matter.
Saygılarımla / Kind Regards
Shahrukh Mirza NAWANDISH
Havacılık Bilgi Sistemleri / Aeronautical Information Systems
Yazılım Geliştirme Uzm. Yrd. / Software Development Assist. Specialist
Bilgisayar Programcısı / Computer Programmer MCA
T:+90 312 266 66 98
M:+90 538 519 72 67
 E:mirza.nawandish at haritaevi.com
▶: Ankara-Istanbul-Bucharest<https://www.haritaevi.com/en/about-us/contact>
www.haritaevi.com<http://www.haritaevi.com/>
www.obstacleanalyze.com<http://www.obstacleanalyze.com/>
www.aixm.haritaevi.com<https://aixm.haritaevi.com/>
www.aerodatamarket.com<http://www.aerodatamarket.com/>
[https://avatars.mds.yandex.net/get-mail-signature/2434044/d24bf65965f2be07edc47ff3c25b0348/orig]<https://www.instagram.com/haritaevi/?hl=tr>[https://avatars.mds.yandex.net/get-mail-signature/200369/c75763261eac7fb671922d147573080b/orig]<https://www.linkedin.com/company/haritaevi-havac%C4%B1l%C4%B1k-m%C3%BChendislik-a-%C5%9F/>[https://avatars.mds.yandex.net/get-mail-signature/2434044/1cd6e615d44979bf9b0d6b0ea9c47182/orig]<https://twitter.com/haritaevi>[https://avatars.mds.yandex.net/get-mail-signature/232821/ec6941b191f27730d3a5f92fd846beb4/orig]<https://www.youtube.com/channel/UCZHA_PmyMLg__KOfNgOLJYg?view_as=subscriber>[https://avatars.mds.yandex.net/get-mail-signature/232821/0545b2da2dc9f49f532774615ec45e51/orig]<https://www.facebook.com/haritaevi/>[https://www.haritaevi.com/wp-content/uploads/2022/02/disclaimer_1.png]<https://www.haritaevi.com/disclaimer> [https://avatars.mds.yandex.net/get-mail-signature/2434044/58c47a3a908e28fdb209656734002f36/orig] <https://fidic.org/> [https://avatars.mds.yandex.net/get-mail-signature/2423644/1ccfc2184635533811e43aeeae4bf6c1/orig] <https://www.efcanet.org/> [https://avatars.mds.yandex.net/get-mail-signature/2423644/405b95fb41fb8db77dcee35ff542f333/orig] <https://www.haritaevi.com/en/about-us/quality-policy> [https://avatars.mds.yandex.net/get-mail-signature/1539903/c89e02562564f32028015473ea475742/orig] <https://www.haritaevi.com/en/about-us/information-security-policy>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240422/f9377961/attachment-0001.htm>
