[gdal-dev] Reading interpolated values on DSM
Paul Harwood runette at gmail.com
Wed Apr 24 01:51:28 PDT 2024
If you want to do it in QGIS ...
https://plugins.qgis.org/plugins/rasterinterpolation/
On Wed, 24 Apr 2024, 09:33 Javier Jimenez Shaw via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi
> I would like to read in QGIS or GDAL an interpolated value in a DSM (well,
> actually it is a geoid model, but it is the same behaviour). See that I do
> not want the pixel value, but the linear interpolation among the neighbour
> pixels, assuming that the pixel value is in the center of the pixel.
> For instance, this file
> https://www.isgeoid.polimi.it/Geoid/Asia/Japan/japan2000_g.html
> Is there any way to get it (without implementing the interpolation myself)?
> If I understood correctly gdallocationinfo is not interpolating, just
> giving the pixel value.
> Thanks
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240424/5711a9e9/attachment-0001.htm>
