[gdal-dev] Reading interpolated values on DSM
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Wed Apr 24 02:09:05 PDT 2024
How about making a VRT file with doubled pixel size by applying your favourite resampling method and then making a query from the VRT file with gdallocationinfo?
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Javier Jimenez Shaw via gdal-dev
Lähetetty: keskiviikko 24. huhtikuuta 2024 11.33
Vastaanottaja: gdal dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Reading interpolated values on DSM
Hi
I would like to read in QGIS or GDAL an interpolated value in a DSM (well, actually it is a geoid model, but it is the same behaviour). See that I do not want the pixel value, but the linear interpolation among the neighbour pixels, assuming that the pixel value is in the center of the pixel.
For instance, this file
https://www.isgeoid.polimi.it/Geoid/Asia/Japan/japan2000_g.html
Is there any way to get it (without implementing the interpolation myself)?
If I understood correctly gdallocationinfo is not interpolating, just giving the pixel value.
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240424/f257b93b/attachment.htm>
