[gdal-dev] don't search side car files on s3 with gdalinfo
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Apr 27 04:01:10 PDT 2024
Hi
I am accessing a big file in S3. All works fine (when I learned how to set
the authentication environment variables), but gdalinfo is checking for a
lot of files that do not exist. I know there is only a GeoTIFF - COG (no
side car files)
However gdalinfo is trying to find several side car files, that are not
there. S3 returns a 403. It takes its time to search for all those files.
Is there a way to tell to gdalinfo that it should not check for those files?
Bonus: QGIS is also taking time to open it (just using 'qgis' instead of
'gdalinfo' in the command line). I think it is for the same reason. It
there a hack there as well?
Thanks.
$ AWS_ACCESS_KEY_ID=... AWS_SECRET_ACCESS_KEY=... AWS_SESSION_TOKEN=...
gdalinfo /vsis3/blah/folder/ortho.tiff
Driver: GTiff/GeoTIFF
Warning 1: HTTP response code on
https://blah.s3.amazonaws.com/folder/ortho.tiff.aux.xml: 403
https://blah.s3.amazonaws.com/folder/ortho.aux: 403
https://blah.s3.amazonaws.com/folder/ortho.AUX: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.aux: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.AUX: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.ovr: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.OVR: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.msk: 403
https://blah.s3.amazonaws.com/folder/ortho.tiff.MSK: 403
https://blah.s3.amazonaws.com/folder/ortho.XML: 403
https://blah.s3.amazonaws.com/folder/ortho.xml: 403
https://blah.s3.amazonaws.com/folder/ortho.IMD: 403
https://blah.s3.amazonaws.com/folder/ortho.imd: 403
https://blah.s3.amazonaws.com/folder/ortho.RPB: 403
https://blah.s3.amazonaws.com/folder/ortho.rpb: 403
https://blah.s3.amazonaws.com/folder/ortho.PVL: 403
https://blah.s3.amazonaws.com/folder/ortho.pvl: 403
https://blah.s3.amazonaws.com/folder/ortho_rpc.txt: 403
https://blah.s3.amazonaws.com/folder/ortho_RPC.TXT: 403
https://blah.s3.amazonaws.com/folder/ortho_metadata.txt: 403
https://blah.s3.amazonaws.com/folder/ortho_METADATA.TXT: 403
https://blah.s3.amazonaws.com/folder/ortho_MTL.txt: 403
https://blah.s3.amazonaws.com/folder/ortho_MTL.TXT: 403
https://blah.s3.amazonaws.com/folder/METADATA.DIM: 403
https://blah.s3.amazonaws.com/folder/metadata.dim: 403
https://blah.s3.amazonaws.com/folder/ortho_metadata.xml: 403
https://blah.s3.amazonaws.com/folder/ortho_METADATA.XML: 403
https://blah.s3.amazonaws.com/folder/ortho.TXT: 403
https://blah.s3.amazonaws.com/folder/ortho.txt: 403
https://blah.s3.amazonaws.com/folder/ortho.RPC: 403
https://blah.s3.amazonaws.com/folder/ortho.rpc: 403
https://blah.s3.amazonaws.com/folder/ortho.pass: 403
https://blah.s3.amazonaws.com/folder/ortho.PASS: 403
https://blah.s3.amazonaws.com/folder/summary.txt: 403
https://blah.s3.amazonaws.com/folder/SUMMARY.TXT: 403
https://blah.s3.amazonaws.com/folder/HDRdisplay.txt: 403
https://blah.s3.amazonaws.com/folder/HDRdisplay.TXT: 403
https://blah.s3.amazonaws.com/folder/HDRho_display.txt: 403
https://blah.s3.amazonaws.com/folder/HDRho_display.TXT: 403
https://blah.s3.amazonaws.com/folder/RPCdisplay.txt: 403
https://blah.s3.amazonaws.com/folder/RPCdisplay.TXT: 403
https://blah.s3.amazonaws.com/folder/RPCho_display.txt: 403
https://blah.s3.amazonaws.com/folder/RPCho_display.TXT: 403
Files: /vsis3/blah/folder/ortho.tiff
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240427/7bb173db/attachment.htm>
