[gdal-dev] lost python api doc?
Michael Sumner mdsumner at gmail.com
Sun Apr 28 16:03:44 PDT 2024
Ah awesome, thank you!
On Mon, Apr 29, 2024 at 8:59 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> The Python doc got reorganized one month ago (
> https://github.com/OSGeo/gdal/pull/9575), so perhaps Google hasn't
> updated yet the new references
> If you look for gdal.warp on gdal.org directly :
> https://gdal.org/search.html?q=gdal.warp&check_keywords=yes&area=default
> that leads to https://gdal.org/api/python/utilities.html#osgeo.gdal.Warp
> Even
> Le 29/04/2024 à 00:52, Michael Sumner via gdal-dev a écrit :
> I'm confused about how to browse the python api docs, I used to just web
> search "osgeo.gdal Warp", and then scan down the first result page to find
> "Warp(" and I had the documentation I needed.
> Where is that now? (Why can't I find it, sorry - grepping the sources for
> "Warp(" only results in RFC 59 references, so I think this might be a real
> problem).
> If I'm just navigating the API docs incorrectly I'd appreciate a
> walkthrough to find the signature and param descripts for "Warp()". Thanks!
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240429/824c66a1/attachment.htm>
