[gdal-dev] HDF5 and geolocation arrays
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Apr 29 14:37:45 PDT 2024
> This HDF5 (requires earthdata credentials your "Authorization: Bearer <token>" in GDAL_HTTP_HEADERS, or equiv) presents without geolocation arrays.
gdalinfo "/vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5" -sd 26
Excuse for this little derail, but how do we do that? I mean, the credentials. I tried with both:
gdalinfo --config GDAL_HTTP_HEADERS=login:passw "/vsicurl/https://n5eil01u.ecs.nsidc.org/…
and
gdalinfo  "/vsicurl/https://login:passwd@n5eil01u.ecs.nsidc.org…
but both errored with
ERROR 3: Cannot read 4029 bytes
gdalinfo failed - unable to open '/vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5'.
and
gdalinfo failed - unable to open '/vsicurl/https://login:passwd@n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5'.
Thanks
Joaquim
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Michael Sumner via gdal-dev
Sent: Monday, April 29, 2024 8:11 PM
To: gdal-dev <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] HDF5 and geolocation arrays
Driver: HDF5Image/HDF5 Dataset
Files: /vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5
Size is 608, 896
Metadata:
  Conventions=CF-1.6
  HDFEOS_INFORMATION_HDFEOSVersion=HDFEOS_5.1.15
  history=This version of the Sea Ice processing code contains updates provided by the science team on September 16, 2019. For details on these updates, see the release notes provided in the DAP.
  institution=NASA's AMSR Science Investigator-led Processing System (SIPS)
  references=Please cite these data as: Markus, T., J. C. Comiso, and W. N. Meier. 2018. AMSR-E/AMSR2 Unified L3 Daily 12.5 km Brightness Temperatures, Sea Ice Concentration, Motion & Snow Depth Polar Grids, Version 1. [Indicate subset used]. Boulder, Colorado USA. NASA National Snow and Ice Data Center Distributed Active Archive Center. doi: https://doi.org/10.5067/RA1MIJOYPK3P.
  source=satellite observation
  title=AMSR-E/AMSR2 Unified L3 Daily 12.5 km Brightness Temperatures, Sea Ice Concentration, Motion & Snow Depth Polar Grids
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  896.0)
Upper Right (  608.0,    0.0)
Lower Right (  608.0,  896.0)
Center      (  304.0,  448.0)
Band 1 Block=608x1 Type=Int32, ColorInterp=Undefined
  Metadata:
    comment=data value meaning: 0 -- Open Water, 110 -- missing/not calculated, 120 -- Land
    coordinates=lon lat
    long_name=Sea ice concentration daily average
    units=percent
gdalinfo --version
GDAL 3.9.0dev-cb4d30f56d, released 2024/04/15
The geolocation arrays are sds 33 and 32 respectively:
HDF5:"/vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5"://HDFEOS/GRIDS/NpPolarGrid12km/lon
HDF5:"/vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5"://HDFEOS/GRIDS/NpPolarGrid12km/lat
And things work when lining those up in VRT with warp. Can the HDF5 driver be made to auto-detect these geolocation arrays?
I see that the NETCDF driver actually does:
gdalinfo "NetCDF:/vsicurl/https://n5eil01u.ecs.nsidc.org/AMSA/AU_SI12.001/2012.07.02/AMSR_U2_L3_SeaIce12km_B04_20120702.he5" -sd 26
I'm asking as an email rather than pursuing the fix because, these data are actually a regular grid on the north and south poles, and so geolocation by arrays is sub-optimal  the specification is listed in
https://nsidc.org/sites/default/files/au_si12-v001-userguide_1.pdf
and the two parameter sets are
Np-north: -te -3850000,  -5350000, 3750000, 5850000 -t_srs EPSG:3411
Sp-south: -te -3950000,  -3950000, 3950000, 4350000 -t_srs EPSG:3412
Is this generally something we should pursue within GDAL? It seems like an endless task to detect-on-open exactly this situation and assign the easy fix, but this is a pretty fundamental data stream and it's very common so the longlat/arrays might be numerically detectable with other heuristics hinting that it's polar (??) and there are plenty of other sources that present equivalents in the right way e.g. this one:
"/vsicurl/https://noaadata.apps.nsidc.org/NOAA/G02135/north/daily/geotiff/2012/07_Jul/N_20120702_concentration_v3.0.tif"
The right approach is probably to inform the providers and get the right metadata baked in ... but there's pros and cons to either. I'm not sure there's even enough information in these files to clearly detect the situation, it would be a bit like the NSIDCbin driver with its very strict requirements.
Cheers, Mike
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com<mailto:mdsumner at gmail.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240429/932176f4/attachment-0001.htm>
