[gdal-dev] Test problem After Merge
Even Rouault even.rouault at spatialys.com
Mon Apr 29 14:37:56 PDT 2024
Andrew,
Perhaps you're running updated GDAL Python bindings against a libgdal
that hasn't been rebuilt recently? OSRIsDerivedProjected() has been
added recently both in libgdal and the bindings
Even
Le 29/04/2024 à 23:27, Andrew Bell via gdal-dev a écrit :
> Hi,
> I just merged master into my branch and I'm now getting an error when
> trying to run a test. If someone might know what happened, I'd
> appreciate a tip.
> (gdal) [master] $ pytest -v autotest/utilities/test_gdal_viewshed.py
> ImportError while loading conftest
> '/Users/abell/gdal.2/build/autotest/conftest.py'.
> autotest/conftest.py:9: in <module>
>     from osgeo import gdal, ogr, osr
> swig/python/osgeo/gdal.py:3942: in <module>
>     from . import ogr
> swig/python/osgeo/ogr.py:608: in <module>
>     from . import osr
> swig/python/osgeo/osr.py:13: in <module>
>     from . import _osr
> E   ImportError:
> dlopen(/Users/abell/gdal.2/build/swig/python/osgeo/_osr.cpython-312-darwin.so
> <http://osr.cpython-312-darwin.so>, 0x0002): symbol not found in flat
> namespace '_OSRIsDerivedProjected'
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240429/8a241bc0/attachment.htm>
